2016TouringSLC
- Feb 21, 2016
- 4
- 80
- 53
- Salt Lake City
- 2016 Honda Civic Touring
You're welcome. Let me know how it goes as I'm intending to do the same thing when I get some time. The amp has a digital input (the round connector on the right side), but I understand that is for all audio other than for the radio and USB connectors, meaning the voice warnings, navigation, Siri, etc. I'm really hoping we can use these high-level outputs to run to a separate processor and amp.I printed this out last night to help me get my High Level Inputs to my amps without needing to pull from each speaker location. Thanks a Ton.
do those colors correspond to the wire directly connected to the actual speakers? like at the pin? trying to hook up my lc6i to get rca to amp, thanks in advance
When I replaced my front speaker and tweeter, the color code from the amp matched the connection to the speakers.do those colors correspond to the wire directly connected to the actual speakers? like at the pin? trying to hook up my lc6i to get rca to amp, thanks in advance
thank you sir, I hooked up the wiring to an lc6i and that to my jx1000 amp. I routed the power cable through the firewall and had to call it a night...this morning the car won't turn on. I'm scared shitless, I mean I didn't even hook up the fuse on the power cable simply hooked up the terminal to the fuse holder and ran the rest of the cable so not sure what happened. the dash lights up like Christmas scrolling through transmission error, acc error, emergency brake error, error, error, error. just called roadside, getting downWhen I replaced my front speaker and tweeter, the color code from the amp matched the connection to the speakers.
that was the first thing I tried, left it disconnected while I showered and got ready for the tow truck. no luckI had something like happen with mine, so I removed the battery cable for a few minutes and reinstalled. Everything rebooted and it was fine. Hopefully that's all it is.
This car is like a giant computer, and sometimes it needs a hard reboot.
well, roadside came and was unable to take the car for 2 reasons. it was on a drive way with a steep downhill and the emergency break was engaged. called the dealership and Richard, the service manager at Sames Honda came to the house and started to work on it. he said the inside of the car, i.e the push start button was not communicating with the engine. he said there was a similar case they had so we was going to bring a new computer and swap it out. that did not work. he brought over another tech with him and they got to work, mind you, outside my house in the sun 103°. I was truly impressed with the service. Richard called in a flatbed and went to go buy wheel dollies to get it off the driveway (only way the tow trucks would take it, due to not wanting to risk damaging the transmission) I've been in contact with Richard since yesterday morning and they are still trying to figure out what the deal is. I'll head over in a bit to get a rental but hopefully this gets resolved quicklyLet us know how it turns out. Would like to avoid a similar experience.
Yep ... I hear ya ...When I used the high level outputs I had no problem. I left about 6" of service loop on the side toward the amp. (the amp in our touring was located in the kick panel just inside the passenger side door. The outputs -HIGH LEVEL_ were wired directly into my aftermarket amps high level inputs. I have had no problem with the system as a whole other than periodic needs for a reboot of the head unit. As a person that does Audio Visual for a living I am not impressed with the sound EQing that Honda did and wish I could disable it and bypass all the "modifications" they needed to do to get the cheap stock speakers to sound reasonable. I will someday spend some money to add in a 13+band eq device to help bring back the sound.
Hey fellow civic owner. First off wanted to thank you very much for posting this info as I am in the process of installing an amplifier and subwoofer. As I was installing I noticed there is a bit of a typo in the chart regarding the front speakers, which I am using to tap my LC2i in to. For A5 you listed it as Front Left speaker + and for A6 you listed it as Front Right speaker +. By looking at the pattern it seems A12 and A13 are correct for the front right speaker. My concern is the front left speaker. According to the pattern I wired it as A5 = Front Left speaker - and A6 = Front Left speaker +. If you happen to know, could you please clarify. I'm concerned to finish up and have incorrect wiring that will be difficult to figure out. Again thanks a lot for the diagram.
