Phone mount
ATM
ATM
FK8
What phone mount are y’all using? Looking for something that doesn’t cover the vents.
GhostRider13506
Ron
Oklahoma
2021 Boost Blue Type R
DAVEEVAD
Dave
Buffalo, NY
2020 Civic Sport Hatch
That is the one I like, I will order one when availble
Yeah, I've been really happy with it for over a year now. It clips on tight and hasn't budged once. Also, because of the ball and socket design you have a ton of options for various phone holders or you can just use the included magnetic plate.
I 3D printed a phone holder for my Note 9 that allows me to slide the phone in and have it plugged in to a USB C for Android Auto.
bugboy32337
Tallahassee
2019 Civic Si Coupe (MSM)
The Bad Guy
Brian
Athens, GA
18 CBP Si Sedan, 06 G6, 15 Silverado
I don't; i simply plug my phone in, then toss it upside down in my cup holder.
DAVEEVAD
Dave
Buffalo, NY
I've been using that one for a few months, and I'm happy with it.
If I had to list a gripe, it would be: when the phone is plugged into a charging chord, the chord will tap the touch screen ... and that can cause some havoc. That said, I almost NEVER have the chord plugged into the phone ... and if I do, I've learned to rotate the phone 90 degrees ... problem solved.
I went with a 90 degree USB C cable (I have Android).
Amazon.com: UGREEN USB C Cable 90 Degree Right Angle, USB A to Type C Fast Charging Braided Cord Compatible with Samsung Galaxy S10 S10e S9 Plus Note 9 8, LG G8 G7 V40 V20 V30, Moto Z Z3, Nintendo Switch (3FT): Electronics
bugboy32337
Tallahassee
Nexus713
Michael
New Jersey
2020 Honda Civic Sport (Sedan)
@ATM I’m using this one:
https://www.amazon.com/GTINTHEBOX-S...der&qid=1623418914&sprefix=Gtinthebox+&sr=8-5
Main reason is, doesn’t cover vents / doesn’t use vents as ‚holder’ which means i can still adjust them. Cold air goes on my phone cooling it in 100+ Degrees weather.
Also the ‚phone holder’ part is removable when i’m not using it, and part that holds it stays on hazard lights button and doesn’t cover anything, neither looks bad 👍🏼 it fits all phone sizes (even my wife’s 12 Pro Max which is huuuge) and that ‚ball’ part which sometimes gets loose and doesn’t hold phone in one place, is adjustable which means you can tighten it more if needed.
That’s how it looks with holder:
