Phearable maps on ECUs without switching
zerain
Australia
Civic RS 2016
Hi all,
was interested in getting the 1.5R Phearable tune for my civic cvt but found that my ECU, although supported, can’t map switch. Which map would the tune default to, or will there be a way when flashing to decide which map is set? Does this also mean there would be no way to switch from map 1 to map 3? Currently have the 21 psi base tune set up and I often use ECO to switch between 21 and 15(iirc) psi.
Side question, would running the 24 psi map at all times be safe for an otherwise completely stock daily? I would only be filling 98 RON (94 for US folks)
