Stockblock
- Pedro
- Jun 13, 2019
- 2
- 37
- 15
- California
- 18' SI
- #16
I did use thicker wire. I was at orilleys just now and my christmas lights are back again. What i noted is power is slightly lacking via ktuner yet when im on Ktune acceleration suffers. Im wondering if my waste gate is faulty. Im about to swap out my spark plugs note my ktune. Pics attachedBased off your previous comments I'd check the continuity of the wires with a multi meter. Even then I'd pay close attention to the pins and maybe even rewire it with a thicker wire, making sure to leave some slack so it. Lmk if that helps![]()
https://www.bmotorsports.com/shop/product_info.php/products_id/2328
P0035 just popped up for me tonight tooIm currently having this same issue. However I checked the wiring and the wires are fine. I kept on turning off the car and turning it back on and after a few starts, the CEL light went away and the code reader no longer reads the p0035. Service department told me to put back the stock intake and drive it normally, but my mishimoto intake has been on for 4 years without issues.
It's the second time it happened. This happened though after changing the battery and doing an oil change. I'm stumped.
Im going to take notes of the possible fixes above and hopefully it works out
I ended up filing a report with the NHTSA because I noticed the 2017 Type R had a recall for this very issue, but i was confused as to why the Si and other models don't. Hopefully it can push for a recall because this definitely can be a safety concern since the car loses power and other safety features.P0035 just popped up for me tonight toowiring seems fine so I’m stumped as well. Very hesitant to replace factory wiring unless I’m certain it’s faulty
Good call. I ended up getting a couple replacement pigtails from Ballenger Motorsports that seem almost identical to the OEM. Worst case I can probably use the pins and wires but I think they might just fit as is.I ended up filing a report with the NHTSA because I noticed the 2017 Type R had a recall for this very issue, but i was confused as to why the Si and other models don't. Hopefully it can push for a recall because this definitely can be a safety concern since the car loses power and other safety features.
I appreciate you looking out and telling me the parts you used. I may look into this fix because Honda just quoted me about $2800.Good call. I ended up getting a couple replacement pigtails from Ballenger Motorsports that seem almost identical to the OEM. Worst case I can probably use the pins and wires but I think they might just fit as is.
Home » Shop » Connectors / Harnesses » Sumitomo » 2 Way Connector Plug Pigtail TS Sealed Series for Sensor Application, Gray Keyway 1 (bmotorsports.com)
OEM for comparison:
Just gonna bite the bullet, replace the wiring, and hope that fixes it. Sucks that this is even an issue to begin with but at least the solution is pretty cheap…
