PERRIN
- Apr 19, 2018
- 13
- 63
- 85
- Hillsboro, Oregon
- Website
- www.perrin.com
- 2017 Civic Type R
The PERRIN Short Shifter Adapter reduces shift knob travel between gears and makes your shifts feel solid and positive. Changing the throw and feel gives a rewarding improvement every time on your daily commute, or on the track. This should be one of the first parts you install on your car to improve your driving experience.
PERRIN.Com
PERRIN.Com
Throw Adjustability
The PERRIN 1-way and 2-way Short Shift Adapters both reduce shifter throw 17%-25%, cutting the distance you must move the shift knob to enter the next gear. (reduction in throw varies by Civic model)
Civic LX 20% to 25%
Civic SI 20% to 25%
Civic Type R 17% to 22%
Knob Position Adjustability
The 2-way adjustable version of the PERRIN shifter adapter additionally allows the driver to adjust the resting knob position forwards or backwards.
Easy Installation & Adjustment
Simply loosen the set screws, adjust the adapter position and re-tighten. It's that simple!
Construction
The PERRIN Short Shifter Adapter is machined from a single piece of stainless steel, giving you a lifetime of corrosion-free performance.
