PERRIN
- Apr 19, 2018
- 13
- 63
- 85
- Hillsboro, Oregon
- Website
- www.perrin.com
- 2017 Civic Type R
Improve the feel of your shifter and remove rattle with the PERRIN Shifter Cable Lock.
PERRIN.com
PERRIN.com
10th Generation Civic shift cables are not well secured in the shifter cable housing. This causes a noticeable "double-clunk" while shifting into 2nd, 4th, and 6th gear. This problem is exaggerated when aftermarket short shifts and adapters are installed.
Locking The Cable Down
The PERRIN Shifter Cable Lock compresses the shifter cable housing around the shifter cable mount, locking it in place and eliminating any movement.
Dampen Vibrations
The Shifter Cable Locks extended shaft uses tension bands to hold pressure on the cable eliminating any additional vibration between the shifter cable and the shifter cable sleeve.
Finish & Construction
The PERRIN Shifter Cable Lock is CNC machined from lightweight aluminum for a precise fit. Anodized black and laser etched with the PERRIN logo and part number. While you won't see it again once it is installed, know that it will still be looking and working great for many years and miles to come.
