Hazardous-Drunk
- Enzo
- Dec 20, 2020
- 7
- 48
- 33
- California
- 20 Si
Figured I'd just give my experience, just got them installed this morning if anyone else may of been hesitant.
First thing right away was the start up.. Its rough, Cold idle you feel it id say 20% more then without it.
Starting first gear normal.. Good amount of vibration.
Shifting gears is extremely solid and 10/10 big improvement.
Downshifts much smoother.
Idle... Warmed up is meh.. You feel it for sure in the wheel.
Idle + AC... If small vibrations drive you nuts, This will drive you nuts.
Overall I'm giving it a thumbs up..
I'll post an update over time maybe give them a bit to break in and give any good or bad news
Also install took 20 minutes and was pretty easy just need 17/10/19 MM wrench/ratchet. Flathead and a Philips screwdriver, Jack and jack stands.
I used the 19MM as a pry bar for the plastic cover but didn't need for anything else.
Ninja edit.. Most importantly wheel hop is gone, totally spaced it, being the main reason I got it.
