PERRIN Intercooler for the Type-R (Test Results Inside)
02SilverSiHB
Colorado Springs, CO
2017 FK8
Nothing at all... the issue is the height of the core.... bumper metal brace is gettin in d way
I know with the JDM it has the same issue. Hks instructions showed them remove it, then put the intercooler on, then put the brace back on. Not sure if that would work for you or not
NarsBaller
Japs
Australia
Civic Type R FK8
these 2 metals are issues... australia spec comes with sensor and stuff as you can see underneath the main bumper brace where it is attached.
NarsBaller
Japs
Australia
Civic Type R FK8
And this is the height clearance before it hits the bumper frame. Stock IC in pic for reference.
metal_driver
Ottawa
2004 TSX (Euro-R mods), 2009 Acura TSX, 2008 MDX, 2011 Shelby GT500, 2018 Type R, 2020 MDX A-Spec
NarsBaller, probably not worth it but maybe you could get a North American aluminum bumper off a part out?
NarsBaller
Japs
Australia
Civic Type R FK8
Im just gonna return the intercooler and get HKS instead. I want to keep the safety features in our bumpers. I just got this Perrin as it was on a good deal but my first option really was HKS. So I guess this one is goin back to the seller.
MrM04
Miguel
San Antonio
20' Civic Type R, Scion xD, (Two Wheels 14' ZX6R)
Let me get this straight. With this Intercooler because it keeps temps so good, the ecu drops boost for the sake of it not needed it? Or at least that might be how it was built to do? If this is the case for a simple blot on for the sake of preventing heat soak, should a daily driver worry about that? Just for clarity your turbo is not creating as much boost but then you have to worry about the catch up boost I guess? With that dip that happens on a untuned car. Am I interpreting that correctly? Looking for some rebuke here if I am not
tinyman392
Marcus
Illinois
'18 Civic Type R (RR)
The ECU controls how much boost to create based on a number of factors. MAF readings and air temps are two major ones, but the intake temps are another as well. If the intake temps are too high (especially compared to ambient) it will reduce boost and thus torque and power. If not, it will set the boost to achieve a pre-set torque target to hit. So if you're at a lower altitude or lower ambient temps (which cause denser air) the ECU will actually pull boost to achieve the same amount of torque/power while in higher altitudes or hotter conditions it'll increase boost. The exception of course is if your intake temps are higher, in which case it will also pull boost to avoid overheating the motor. These higher intake temps are normally caused by the intercooler getting heat soaked.
For a daily driver, sitting around in idle in traffic will cause the stock intercooler to heat soak pretty readily. Even driving around in traffic at a steady 50-ish MPH has caused it in my experiences. The PRL is able to absorb more heat before completely soaking which means the heat soak doesn't happen as quickly, but eventually will. If this eventually is longer than the drive itself, the driver will never experience it, which has been my experience with the intercooler. If I'm not mistaken a lot of intercooler manufacturers have noted that the car will lose upwards of 20-25 WHP with the intercooler heat soaked (this can happen after as little as 3 pulls). This is about 8% power loss caused by the ECU cutting power.
However, if you go over to a track scenario, then this intercooler will soak and have issues letting go of the heat. This is even when compared to the stock intercooler which tends to do better on a track scenario (thus why HPD runs a stock intercooler on their TC race car). For track use, other heat issues plague the FK8, but the intercooler isn't the huge factor (though there are some better intercooler designs for track use, you likely wouldn't want to use them for the street).
MrM04
Miguel
San Antonio
Thanks for the response. My biggest goal is to make the car perform as expected every time. Looking into getting intercooler pipes coated with ceramic to help with heat soak. More power is cool , but reliability is better.
tinyman392
Marcus
Illinois
A new intercooler does change the response of the car, so what's expected will change, but it'll end up like that more or less every time unless the temps really rise. I don't know if ceramic coating the tubes would help as that might work more as a insulator than it does anything else. I could be wrong on that though.
xdecemberguy
Randrew
Honda Civic Type R
I love this intercooler on my Type R. Looks good, great quality, and works well.
shadow
Philippines
11 STI, 15 CRV, 16 Civic RS Turbo, 18 Civic Type R
For other non-USDM Type Rs out there, the PRL intercooler fits well. Luckily I snapped a picture while doing my fog lights.
