PERRIN Intercooler for the Type-R (Test Results Inside)
Ctr1
Washington
18 CTR, 12 Speed 3, 03 IS300, 94 EG, 08 Highlander
Good eye!!
What you are seeing is a prototype engine oil cooler and transmission cooler. I am not sure we will end up making the tranny cooler version. I have found that under extreme conditions, that adding an engine oil cooler helps relieve enough stress from the radiator's cooling duties that the tranny cooler may not be needed. Then adding an additional cooling method (being vague on purpose) for the engine seems to eliminate that need. But we have the parts to be able to build them and it is something we could be if someone asks. Then engine oil cooler kit is all done and just wrapping up some instructions, then you will see the launch very soon.
Thanks for the update. I am looking forward for the oil cooler release and testing data.
GraphiteAZ
Tucson, AZ
Civic
When could we expect a radiator with an actually larger cooling capacity, unlike what we have offered from koyo and full race, which seem more like oem replacement and don't give better cooling over oem when on track?
PERRIN_Jeff
PERRIN_Jeff
Hillsboro, Oregon
2017 Civic Si Coupe
  • #18
Very soon! I wish we had more track data and abuse, but we have been running this for about a year now!
I think we have a good grasp on this, and something to look for in the coming months.
turboR
Joe
Newbury Park, CA
2018 CW CTR #18775 / 2002 NB Miata (track car)
I don’t see an intercooler piping kit to go with your awesome intercooler on your website, is there one in development?
PERRIN_Jeff
PERRIN_Jeff
Hillsboro, Oregon
2017 Civic Si Coupe
  • #20
We do not have anything in development yet. Before we get there, we need to prove that it actually makes power. The only pipe that really appears to be an issue is the one at the throttle body with that sharp bend. But we will be working on something, it may just be a next year kind of thing. Keep an eye out!
ebatr24
Oregon
Just ordered an intercooler today, I saw mention of the chance of a black powder coated option. Any chance of being able to get one? I think it would look great with white PERRIN across a black core. :cool:
m_kluch
Maryan
Michigan
2018 Civic Type-R
Just installed the Perrin IC. Fitment was great. I cut the bumper plastic pieces as instructed. Had quite a bit of trouble getting bottom of bumper into place because the intercooler takes up so much space. There is not much wiggle room. Got it for $488 shipped from emnotek on April 1st. Looking at some 4th gear pull datalogs, the charge air is cooler at the end of the pull than at the beginning of the pull so its doing its job wonderfully. This was with outside air temps of 55F. Overall Im very happy with it.
BoostedDreams
Heisenburg
South East Florida
2019 Type R, 2006 Mazda 6
I don’t suppose that deal is still available ?
m_kluch
Maryan
Michigan
2018 Civic Type-R
What r the dimensions of 27won? I wouldn't want any bigger in square inches than this so as not to block too much air flow to the radiator. I think that this IC is very well thought out as far as size goes. Not too thick to maintain cooling efficiency and not too big to block off the radiator. The prl one I think is also very well thought out. I chose this one due to the deal that popped up
02SilverSiHB
Colorado Springs, CO
2017 FK8
Width is the same as oem. Height is 7.95 and thickness is 3.7
NarsBaller
Japs
Australia
Civic Type R FK8
Bought this one and it doesn't fit the Australian spec FK8. Unfortunately here in Australia we have a different bumper frame. Wasted my time removing my bumper.
