Passenger side window and sunroof stopped working
sunny786
Calgary
2008 Honda CRV
how to fix the sunroof and passenger side window? What caused to stop working them?
sunny786
Calgary
2008 Honda CRV
Found the fix. Passenger side window button fixed the problem.
sunny786
Calgary
2008 Honda CRV
You replaced the passenger side window button? And it fixed the moonroof/sunroof?
No, tried few times to operate with that button and that fixed sunroof and passanger side window operation.
calonzo
New Haven, CT
2016 Honda Civic Touring
If it happens again, definitely have the button replaced. On my wife's Acura, we had a similar issue and ignored it. Then the battery went dead a couple of times, but the dealer found nothing wrong. We told the dealer about the window switch, and it turned out the button had a short which drained the battery.
asanjur
Abdy
Panama
2016 Honda Civic EX-T
I have this same issue. Does anyone found a cause/solution to this?
I notice that all of this suddenly stopped working
Moonroof
Passenger side Window
Passenger side view mirror
Trunk release botton
I double check all fuse and everything seems to be ok.
Help Please!
tacthecat
Cheshire, MA
'12 Civic Si Sedan
From prior posts - cycle the passenger side window up/down or down/up FROM THE PASSENGER SIDE WINDOW SWITCH. This seems to fix/reset the logic that causes the fault for the MR & passenger side window (this is first time I've heard of the mirror and trunk being involved but it will likely work).
