My dealer said they fixed it and told me it's from my sub control install in my centre console.F93GH1016...?
Don't let your dealer bully you with aftermarket stuff. They have to PROVE your sound system is responsible.My dealer said they fixed it and told me it's from my sub control install in my centre console.
I'm skeptical that would ever have been touched during installation but I was too lazy to check to see if that actually makes any sense, and I do have a pretty evident aftermarket sound setup so... I guess I will see if it's an issue again.
Could you please take some pictures of the evaporator drain hose? Thx!Update:
The dealer removed the seats and console, dried the floorpan and replaced the carpet and insulation under warranty. They said that the A/C evaporator drain was "not hooked up". All of the condensate from the evaporator was draining into the interior of the vehicle.
The hitch was that the carpet/insulation was on backorder. This makes me suspicious that many others are having the same problem. The carpet arrived in about two weeks. The dealer provided us with a dealership loaner for a few days and then switched us to a Buck Enclave from Enterprise when the learned of the backorder.
I wonder if the evaporator drain hose was ever connected from the factory, worked loose during normal operation or was jarred loose during the repair procedure of the 2 litre recall campaign for the piston snap ring. In any case, I will be adding a worm clamp to the evaporator drain hose to ensure that it doesn't happen again.
This is the only blight on an otherwise fine car.
At least point us to the area it is located under the dash.Could you please take some pictures of the evaporator drain hose? Thx!
Here are some pics of the evaporator drain hose. It is straightforward to check. Tools are not needed.
This pic shows where the tube connects to the HVAC housing. This is the front passenger side. This is where I believe the tube was not connected. Note that the carpet is moulded so that it clears the drain tube. Could my size 14 shoe have knocked it loose? There is no protection provided underneath the carpet. Without touching anything, a small section of the hose can be seen.
Here is the carpet partially pulled back to expose more of the tube. It was firmly and fully seated on the HVAC housing. I had said previously that I would add a worm hose clamp to ensure that it would not inadvertently disconnect. At this point, I do not know if the hose was not connected at the factory or worked its way loose. An added hose clamp will ensure the latter does not happen.
I have owned Honda/Acuras since 1994 and I must say that this Civic has more sound insulation than anything I have seen before. It is even thicker than in the 2011 TL that I have. That extra-thick insulation make a great water absorber when the evaporator condensate leaks into the floorpan. It would be impossible to dry out. Those with failures, make sure that you insist on new carpet and insulation. One part number supplies both.
This pic depicts the path of the drain tube. Most of the Hondas that I have worked on in the past use a tube with an immediate 90 bend that exits the firewall. No more than a couple of inches inside the car. For some reason, the tube in the Civic takes a long path and exits near the screwdriver tip. It exits through a rubber grommet in the firewall/floorpan.
Jeff
Yes, we got the Weather Tech Floor mats too. Also, on the few days we had where the temperature was lower, the sloshing went away. We also had condensation on the windows too. Interesting also that we've had the car since April, and with such a hot summer, the problem only showed itself a week and a half ago. If the hose was incorrectly installed initially, I can only assume that the water had been building all summer until it was loud enough to hear. We never use the back seat. Now the water is also in the front passenger floor too. Also, in the last few weeks before we noticed the water, my husband complained in the morning that there was condensation on the inside of the windshield, but he attributed that to our using a sun visor and the excessive heat. Possibly it was the water all along. But I guess there is a possibility that the hose worked itself loose over time. But there is rarely a passenger, so I don't know.One would think that the sponge action of the insulation would prevent water from sloshing around, but I think mine was sloshing between the rear seat heat ductwork and the floorpan. The carpet/insulation is on top of the ductwork, so it does not touch down at the bottom where the water would accumulate.
My car had lots of accumulation as evaporation would be difficult due to the Weathertech floor liners. Besides, the condensate output of the HVAC would probably far exceed what could naturally evaporate. The last two days before it was presented to the service department, there was major condensation on the inside of the windows in the morning. The temperature was lower those days.
I'll bet the warranty claim was north of $2,000: replacement carpet/insulation, labour to R&R, plus a fourteen-day car rental.
Thank you very much! Great info and pics. I only had one Civic, my 85 hatch had this problem. And as you say past Honda's the tube exited the cabin through the firewall very quickly. Mine always got spiders up in it.Here are some pics of the evaporator drain hose. It is straightforward to check. Tools are not needed.
Jeff
