P04F0 Code
rallyered225
Daniel
Baton Rouge, LA
2019 Honda Civic Type-R
Could this code be caused by a loose connection around the intercooler? Or does this strictly apply to the EVAP/Purge system? Trying to diagnose why I'm getting this code with the HKS intercooler, piping and intake with AFR.
jdm_mike
Acura Canada
20 FK8 CTR & More
I got an advance diag procedure for the EVAP when I ran the code on my end. Nothing about I/C
tinyman392
Marcus
Illinois
'18 Civic Type R (RR)
rallyered225
rallyered225
Daniel
Baton Rouge, LA
Swapped out the HKS to the PRL. Drove around for a few miles and those two codes won't clear.
rallyered225
rallyered225
Daniel
Baton Rouge, LA
Not sure what to do now. Any advice?
DRUSA
Dan
Palm Springs, CA
2023 Civic Type R 2000 Honda S2000
It's EVAP purge flow related. At full-boost WOT the engine is trying to do an EVAP purge into the intake flow, it checks the fuel tank pressure to see that there has been a change during this event, if there is no pressure change it assumes a line is blocked, disconnected or there is a purge nozzle blockage. Refer to the thread that was linked above, you most likely have a line disconnected or installed wrong on the intake you installed. In the linked thread, OP forgot to connect an EVAP hose back.
rallyered225
rallyered225
Daniel
Baton Rouge, LA
Looks like it worked itself out after swapping to the PRL. Codes went away after driving around for a while.
rallyered225
rallyered225
Daniel
Baton Rouge, LA
What about the fuel pump recall? I recently had this done at the dealership. Could this be causing the codes?
Centripetal
Boston, MA
2006 RSX Type S, 2017 Civic Type R
I figured I'd follow up here and not hijack the PRL intake thread. Did you check the hose? Believe it or not, even a small pin hole can cause an issue like this. Unfortunately, those hoses can be easily deformed. Especially, with those sharp hose clamps that like to cut me.
Honda Civic 10th gen P04F0 Code fb_img_1624541126838-
rallyered225
rallyered225
Daniel
Baton Rouge, LA
I checked the hose. I think it was just poor picture quality. Didn't notice any tears. Ended up removing the factory clamps and installed better hose clamps around the EVAP.
  • Like
Reactions: Myx
Centripetal
Boston, MA
The factory hose clamps are actually quite good at sealing. What did you replace them with?
