P0130 code with catted rv6
Beach civic si
Bert
Corona ca
2019 civic si
Was just wondering I just connected my rv6 catted downpipe to my 2019 civic si and got a CEL within 3 miles of driving. When I data logged the afr was frozen at 27 so the sensor was obviously need reading properly making the car run lean
I then switched back to stock and the CEL was gone and ran perfect
Then tried rv6 again thinking I messed up somewhere during the connection but again the p0130 code flashed again
definitely seems like it’s the pipe
Would I have better luck with the prl catted pipe
I thought the CEL wasn’t really an issue with the catted dp
Frustrating
Multaq
Nick
New York
2018 Civic LX 6SPD
Frustrating
These cars are very tricky with the CELs. Your best bet is to run the downpipe without the defouler and disable the P0420 code in Ktuner. Than you will be CEL free.
10GenPearlSi
Old Man
Bob
Houston, Tx
2018 Pearl Si
You probably just got a P0139 CEL. Just turn the defouler in a couple of turns.
RV6's solution
10GenPearlSi
Old Man
Bob
Houston, Tx
2018 Pearl Si
I got the same P0139 code, I just disabled it with Ktuner, im assuming this causes no issues?
The only possible issue is with state inspection. I guess that varies from state to state.
Ben0012
Ben
Virginia
2017 Civic LX Sedan 2.0 CVT
Thanks, I should be good there, they just visually inspect that a cat is on the car.
