Overheating & What You Can Do To Stop It
Jwolf
I Think I'm Fast
Toyota 86, '19 CTR, Some other stuff
I guess my personal car being tracked in 100F+ weather equates to zero evidence.
If you have the budget to V mount the radiator please do and report back with your findings
At this point, I think a lot of people are looking for the lowest cost solution possible, at least, I am.
b2point0h
Brandon
Im surprised this thread is still going ?
Myself along with many others have figured out solutions already and we arenā€™t overheating anymore, so I donā€™t know why people keep bringing this up.
1. Get a better radiator. Wether thatā€™s the C&R, or a Koyo with the Acuity hoses. (I went Koyo with hoses, but a friend of mine went C&R).
2. Tune. Ditch the stock tune for an ethanol based tune. (I went for e25 on 24psi. Friend went Flex base tune. Neither of us overheat)
Optional:
I went further and got a vented hood, high flow grill and oil cooler. Problem solved.
circuit.heart
Brian
San Jose, CA
'18 Sport (Si converted), '94 525i x2
Optional:
People don't want to accept the truth lol.
The hood is the biggest factor, just ball up and cut it. Once the hood is vented, changing the radiator makes an even bigger difference, an oil cooler helps further, and combined with an ethanol tune you are reasonably set for a non-aero FK8, even if you're a fast driver.
When aero gets involved, the loads climb as well and all of this goes out the window. I've yet to see an aero-kitted CTR be able to do endurance laps besides the THRW Thunderhill cars, and those guys have done some *work* (I helped out in 2018) on the cooling front.
kefi
oh shit waddup its dat boi
Central Florida
fk8.clinic
2018 Type R
Also, my tuner recommends using a custom thermostat. Anyone here done this?
Found a Spoon version
https://www.jdmyard.com/spoon-sports-low-temp-thermostat-17-fk8-civic-type
Thermostat wonā€™t do shit except make your engine run cooler when you arenā€™t putting any load on it, which technically isnā€™t a good idea because the engine clearances were designed with a certain amount of thermal expansion in mind. Absolute snake oil and makes literally zero difference on the track where youā€™re going to be way past the regulating temp anyways.
Iā€™d get a new tuner if they donā€™t even understand that concept.
It's such snake oil that it causes a CEL and Spoon just shrugs their shoulders and says it's probably a defective unit, even though the CEL literally describes what the thermostat does. Coolant isn't reaching normal operating temperature.
shadow
Philippines
I've been studying the upper grille opening of the 2017-2019 FK8. Below is a picture of what you see looking straight into it.
Honda Civic 10th gen Overheating & What You Can Do To Stop It 2020-12-19 15.25.44
The driver's side (LHD vehicle) of this upper opening channels air into the intake. However, 3/4th of the opening (passenger's side) channels air up and above the radiator. From there, it crashes straight into the bulkhead assembly, then down to where the turbo and downpipe are. I think that increases the air pressure behind the radiator. We want low pressure behind the radiator to pull air in from the front. Refer to smaller red arrows in the first drawing below.
Honda Civic 10th gen Overheating & What You Can Do To Stop It Grille
What if we put a sheet metal shroud/diverter to direct the air down towards the radiator? See the green line and arrow above. Do you people think it would somehow help with cooling?
RepyT
Almost Stock ā€˜19 R on 255/35-19ā€
Dave
Destin, FL
2019 Civic Type R FK8, 2017 Lexus GX460 Luxury
Sounds.reasonable, you going to try it and see if it runs cooler?
if so, patent as the Shadow Shield.
ApexEight
Anthony
Atlanta, GA, USA
2019 Honda Civic Type R
@shadow good observation man. I think it's worth a shot. Probably won't be game changing but every little bit helps. Isn't that entire horizontal slit area not present in the 2020+ grille? I believe someone said that the 2020+ intake is somehow fed air through the main opening.
shadow
Philippines
One day I'll get around to fabricating it. Unfortunately I do not track anymore and won't be able to test it's effectivity. I'm just throwing out ideas because I understand the frustration. I used to have an EK with a supercharged ITR motor that overheated after 6 laps.
ApexEight: Yes it's the entire slit that is not present in the 2020+ grille. However, the plastic part you see in the picture I posted still exists. The driver's side still channel's air into the intake. The difference is, air is now coming from a few inches below, where the mesh is.
You are correct that this will not solve the problem, but every bit will help.
Gansan
Glen
San Diego, CA
1999 NSX, 2018 Civic Type R
Has anyone tried water injection for additional cooling?
Unfortunately that's not the kind of cooling that's needed. Water injection cools the intake charge so that you can prevent pre-ignition or detonation in the cylinders, allowing you to run higher compression or more boost. It doesn't actually cool the engine.
RepyT
Dave
Destin, FL
Yes, the needle didnā€™t hurt too bad and I do feel cooler but it had no impact to the Rā€™s track overheat tendencies.
dwag0588
David
Chattanooga, TN
You've essentially just designed the 2020 grille. It has no mail slot in the top and the bottom opening is larger.
kefi
Central Florida
fk8.clinic
2018 Type R
Anybody had luck with detuning on higher amounts of ethanol? The boost would have to be heavily limited but the ignition advance could very well get it back to at least stock power levels, and ethanol is known to run cooler.
