Hondanickx
- Nick
- Jun 10, 2018
- 61
- 1,041
- 789
- Belgium
- 1998 civic hatch , 2018 civic sedan 1.5T
- Build Thread
- Link
- Vehicle Showcase
I know this has been asked several times but i havent found anyone giving a clear answer .
Last weekend i needed to do a oil change and tried to install an universal flat oil sandwich adaptor to install my oil temp and pressure sensors.
The 1.5T engine has no room for the sensors without using a special angled adaptor or using a very thick sandwich adaptor(which extends the oil filter very close to the ground).The ac compressor is also in the way .I used a 3d printed adaptor as a spacer to see if that works ,it does but the oil filter would be dangerously close to the ground.
On A FK8 the oil filter is angled away from the ac compressor and there is more room for the sensors.
Using a universal flat sandwich adaptor doesn't work.
The only way to install these sensors is to either use a specially made angled adaptor like the MAP performance or ETL oil cooler kits have or install a remote T piece with a flex line from the oem oil pressure port and install the temp sensor in the oil pan.
Either using a drain bolt with 1/8npt thread in it or welding a 1/8 npt bung on the oil pan.
The oem oil pressure sensor is located on the front of the engine below the Turbo inlet pipe and above the ac compressor.
It has a 1/8 BSPT thread like all other honda's.
For routing the cable's @metal_driver gave a good idea where there is a opening into the cabin .
metal driver install
