Oil filter wrench
conbrio
conbrio
Edmonton
2017 Civic Hatchback 6MT SGP sport touring
I've been using a pair of these over the last 10 years -
Yes I saw those at Princess Auto. Seems like there are many options to choose from when it comes to an oil filter wrench!
Siiick
Texas
21 GT500, 20 Bolt EV, 19 Z06
I've yet to run across an oil filter that they didn't work on. I get a new car every 2-3 years so having a universal oil filter wrench has come in real handy :)
bbeem
Ben
Iowa
:agree:That's the best type for civic and most vehicles. That's what I use if I need one, I have the 3 other types and they suck.
Gruber
Mark
TN
For s long time I never used a torque wrench on filters, but now I started doing it, for the following reason: why not. Of course I never had any issues, because exact torque is not so critical on a rubber seal, but hand torquing with oily hands is very random. So it usually results in over-torquing in particular by the services, and then the need to use any brutal contraptions to remove the filter.
The OEM filters A01 actually have only torque-based instructions on them, while various other filters have usually instructions based on turns from the point of contact.
I have all kinds of wrenches for filters and I remember struggling with removing filters installed by various services on my cars to the point of totally demolishing the spent filter. Now I just use the socket that fits the filter (which btw. is 64 mm flat to flat and seems exactly the same as similar Toyota OEM filters) plus a ratchet with an extension. The tool shown above is not universal at all. It could be impossible to use it on cars where there is no space for it around the filter.
The torque on these Honda A01 filters is 7.5 to 10 lb ft (or 90 -120 lb in). The similar filter for Toyota says to turn it 3/4 turn.
Honda Civic 10th gen Oil filter wrench 3A04EB86-909A-4747-B140-5F40B1BCF54C
Gruber
Mark
TN
anybody with half common sense would never tighten a filter with oily hands,
wear a clean rubber glove for grip, and it is not random,
that is the way i was taught, by a licensed mechanic,
i have installed more oil filters then everybody on this website combined,
about 30 a day, 6 days a week, for 4 years
When you change your gloves to tighten the filter, I get the torque wrench.
David Harper
Crystal Lake, Il.
2016 Civic coupe
go to the auto parts store with your oil filter and find the correct fitting socket for it. This works better than anything else on this thread.
chriser0
Christopher
NKY
2018 Civic Si
I use one of these, this is universal.
FYI, This will not work for your RAV 4. But these are good for removing regular style filters. A bit tricky the first time you use them though. These also do not alow you to install them.
fitter_here
Ste-Anne-des-Plaines, Quebec, Canada
Civic LX 2016 Sedan
This is why it's called an oil filter removal tool, I never use a tool for installation.
Like Conbrio said before, it's a hand job only..lol
Dario1101
Dario
Miramar, Florida
2021 Honda Civic Hatchback Sport
I have one of these. It scratches up and dents the old filter, but that doesn't matter to me since the filter was going to be thrown out anyway. Great little tool!
Dario1101
Dario
Miramar, Florida
Always try to grab the filter at the outer edge, meaning furthest away from the engine, that's where it's the strongest, and will not crush as easily
Thanks for that tip! I'll remember that for next time!
jsharon
Justin
NY
2022 BRZ Limited 6 Speed
Am I the only one that didn't have a tool the first time so stuck a screwdriver through the filter to get it off when it was stuck...
Gruber
Mark
TN
I never had to go that far, but I've had several struggles, sometimes ending up in the filter looking like a bulldog was using it as a toy. So I have an assortment of filter removal tools. All these cases were caused by someone changing the oil making damn sure the filter would never ever come off accidentally. (this could even have been me on a couple of occasions, before I learned) Here is one list of some tools and tricks:
https://focusoilfilter.com/unscrew-tricks/
and there is even this good comment there: " not all filters are that accessible and some tools used wouldn’t fit in a modern engine."
