Oil change
Average Joeee
Joe
Pennsylvania
2018 Civic Si Coupe
What percent do you guys reccomend I change my oil at currenty its every 5000 miles or 6 months but it just hit 20%
BigRedtheGinger
Jonathan
Moreno Valley, CA
2020 Honda Civic Sport 6MT, 1988 Honda CRX SI, 1997 Jeep Grand Cherokee Limited 5.2 V8
As a mechanic of 11 years, it's ok to change the oil early. I tend to run my Civic 2.0 to about 8,000 miles or so(about 20%), but I also use Mobil 1, Wix XP, or K&N oil filters with either Mobil 1 or Castrol Edge oil. Oil these days is way better than back in the 80s and before, and newer engines tend to have less blow by than older engines, helping the oil last longer. My wife tends to change the oil on her Smart car once a year, but she barely did 10,000 miles a year before we moved to the mountains. She also uses full synthetic oil in that with a good filter.
Fun fact: Smart cars used a bored out Mitsubishi Kei car engine.
VTecYoSelfB4UWreckYoSelf
Kevin
2020 Civic Si Sedan Aegean Blue
I split the difference and change at 7500 miles which leaves the oil around 25% life. 5k is overkill.
TonyTheTiger57
Anthony
Saint Louis Missouri
72 T-Bird, 78 Cougar, 84 Bronco, 85 F150 17 Si
I changed mine after owning it a month, the dealer said they changed it when I bought it but at only 2,000 miles of my driving, the oil came out black. I changed it with a WIX oil filter and a Mobil 1 and a quart of Synthetic Lucas treatment
TonyTheTiger57
Anthony
Do any of you add a magnetic oil drain plug? I do this to all of my vehicles. It is amazing at how much metal it catches.
SDAlexander8
Steve
Indianapolis, IN
When my minder gets to around 30%, there is a change that occurs and I get a noticeable amount of more engine sound. Rev match downshifts are much louder and raspier. It also sounds like it’s running worse on cold morning cold starts.
When I get fresh oil in it, it’s night and day how much smoother and quieter it is. Call me crazy, but something changes chemically around that time. I check the oil regularly. It doesn’t consume a drop.
Maybe it’s fine. The oil that is 5000-7000 miles deep since the last oil change could still be lubricating just as well. But I want that bitch running as smooth as it is now at 200k miles.
ValkenDnB
Luis
Civic
Same happens when you switch to 5w20 or whatever thicker oil than OEM. It’s crazy how loud the engine sounds with 0w20 oem compared to 5w20 torco oil.
Naimahab
South Florida
2017 Honda Civic Si Coupe
This thread makes me paranoid. Is 3500 too often??
joe3456789
Joe
Memphis
2019 Honda Civic Hatchback
I change mine exactly at 5000 miles. I also use Mobil one and I use the OEM filter.
Average Joeee
Average Joeee
Joe
Pennsylvania
2018 Civic Si Coupe
What so you say running thicker oil will quiet the engine noises?
