Oil Blow Off Tube??
2112
Cleveland, Ohio
2017 Honda Civic Type R #00969 BLK, 2015 Nissan 370Z Roadster (BLK), 2019 Civic Si Modern Steel Metalic
Is this some sort of oil reservoir blow off tube or something? I assume some minimal oil residual or spillage in the area makes sense then? Appreciate our expert advice.
Side note - Installed an Injen SRI last night. Is the heat shield suppose to contact the engine housing via that strange tube trim they had me install to the heat shield??
Thanks
2112
Rob_13
Los Angeles 626
2016 Civic EX-L Coupe
mine was dirty too, but i had just assumed it was just from the dealer being messy. as far as it being a tube if i remember its just a solid rubber piece that just a handle could be wrong though.
Honda Civic 10th gen Oil Blow Off Tube?? IMG_3549
Civics4Ever
Rally Red EXT
Gene
Illinois
How old is your car? I had oil collect in the exact same spots, I soaked it up with paper towels and it never came back. This happened 2 weeks after I got it. I believe it's just from factory assembly, or oil that the parts were coated with.
Civics4Ever
Rally Red EXT
Gene
Illinois
That's the transmission fluid. What you likely thought was oil, was just grimy water that made its way there.
If you're leaking transmission fluid you'd know it.
How do you suppose it got there? I swore I looked mine over really well and it wasn't there when I brought it home. I found it a couple weeks later. But like I said, it never came back.
inv4zn
Vancouver, Canada
'16 Touring
The area next to the Tranny Fluid plug is a "dimple", like a bowl.
Dirty water could have kicked up, come down from above, any other way.
Tranny fluid is light pink to dark brown, and there's really no way it would "erupt" out of the hole.
Draken187
Connecticut
2013 accord ex-l sedan, 2016 accord sport sedan, 2006 civic type r (in spain) and 2017 civic sedan ex-t w/manual transmission
Thanks
2112
Lol.. Next time u see something that is labeled.. In this example hcf-2... Google search it..
Quicksipper
FW Tx
16' EX-T, 05' LX
I think he was more concerned about the oil collecting...not what type of oil it is. lol
