kefi
oh shit waddup its dat boi
- Jan 8, 2020
- 14
- 1,614
- 2,523
- Central Florida
- Website
- fk8.clinic
- 2018 Type R
- Build Thread
- Link
@edgeautosport.com the experts on this platform (myself included for the R) don't claim that a BOV will damage your engine in and of itself. Running rich isn't something that usually causes damage. If you want the sounds, go for it - but the customer should be aware that a BOV does mess with how the ECU operates the engine. The issue is that there are many vendors and owners who claim it's perfectly fine and stick their fingers in their ears when the basic theory is laid down.
The reason everyone's so pissed about this video and others like it is because it actually explains nothing, and simply says 'it's OK to use, also turbosmart is great, all BOVs arent created equal, turbosmart is my favorite, by the way turbosmart turbosmart turbosmart, heres a dyno sheet, turbosmart'.
I'm not an expert on the base or Si models, so I'll have to leave that one to @D-RobIMW.
However, on the R, the problem is a little bit more significant. The Type R uses a Bosch ECU that has an extremely sensitive but significantly more accurate airflow model. It uses the pressures inside of the charge pipes (both boost pressure before the throttle plate and manifold pressure after the throttle plate) in combination with the MAF sensor to determine exactly how much air is flowing into the cylinders themselves rather than just measuring overall engine flow at the intake.
If air is released from the charge pipes, the calculations will assume that air flowed into the cylinder and will artificially modify the air charge. Almost every table on the Type R has an air charge index, meaning most of the engine's targets will now be incorrect. Fuel mass, ignition, cam angles, volumetric efficiency, injector phasing, knock retard are all looked up by air charge. This is wildly different from other Honda ECUs.
Part of the reason why the Type R has seemingly the most reliable engine out of any Honda ever made is because the ECU is targeting things much more precisely and compensating for all kinds of variables while it does it. This is also why we can add almost any part to an R and we donât need to tune for it to work properly. Adding a BOV may be harmless, but it most certainly has an effect on these ECUs.
https://fk8.wiki/Hondata_Tuning_Guide#Air_charge_model
