D-RobIMW
www.imwtuned.com
- Derek
- Oct 15, 2017
- 379
- 1,075
- Carlisle, PA
- 2017 Civic Si, 2019 Accord Sport 2.0T, 2001 Integra Type R, 2019 RDX A-Spec
Bisi is the laughing stock of the Honda performance world; he's a washed up has-been that is desperate for attention in a market that has passed him by. He can talk about "working with Honda directly" all he wants, but all it does is make him look even worse. If he has "worked with Honda", he should have a much better understanding of how the ECU controls boost pressure using the bypass valve in addition to the pitfalls of venting metered air on literally ANY airflow-based fuel model.
Let's start with why this video is flawed.
Any time you are dealing with an ECU that uses an airflow meter (MAF, AFM, whatever you want to call it), any 'leak' after the sensor will result in an incorrect allocation of fuel to the engine. Not only does it use this for fueling, but on the 10thGen Civic platform, the ECU also used the MAF signal to partially determine load for the main ignition table.
The video shows lots of high throttle loading, a slow sweeping ramp test, and some quick jabs of the throttle on and off. The big problem with swapping the factory bypass valve comes when the ECU decides to cut off the pressure signal to the top of the valve's diaphragm in an attempt to vent air to eliminate pumping losses at part throttle (for fuel economy), or on spool-up in the event of a boost pressure target overshoot event. This can be observed best with a short WOT pull in a lower gear on these cars, where the wastegate doesn't have enough time to open or close quickly enough to achieve the boost target., so the ECU closes off the pressure reference to the valve and differential pressure alllows the valve to open to regulate charge air. What happens if the bypass valve spring pressure is changed and takes more pressure/force to open? There's a delay in response time, and you have yourself a situation where the wastegate can't act fast enough to open and bleed off exhaust energy to limit boost to the target commanded by the ECU... especially when used with the fast-spooling, tiny factory turbo that can make significant pressure at low engine speed and light loading.
If you're venting air the ECU has accounted for, there will ALWAYS be an error in fueling that can be seen clear as day in fuel trim (short term trim usually, but in the event that the bypass valve sits open at idle, this will transfer to long term trim and learned fueling as well). The ECU does act very quickly, so you probably won't see the change in AFR if you're using an external wideband or sniffer on a dyno, but rest-assured, the ECU sees the change and responds with a sharp negative trim.
There are some people that are content with things that "work fine," and some of us that are only content when things work PROPERLY. Guess which one Bisi is.
P.S. My reply to his YouTube video contains no profanity. He just can't stand being wrong on his own platform.
