Official RV6 R365 turbo thread
kshawn
Matthew
Maine
2017 Civic SI
Sport-injected
Sport-injected
Scott
Central Jersey
www.youtube.com
All replacement housings have been shipped. Happy new year guys.
I received mine, sending out for jethot coating before install. Thanks Rich. Happy new year to you as well.
Sport-injected
Sport-injected
Scott
Central Jersey
www.youtube.com
So since my turbine housing was already seperated and boxed up from RV6 I decided to send right away to jet-hot for their 2500 series coating with a graphit color finish. They quoted $290 which is kinda pricey but I'm hoping this will lower the temp since the TIP sits right on top of the turbo. I figured since it was apart I'll do it right.
Anybody else do any sort of heat coating or blanket?
ManitobaSI
Scott
Manitoba, Canada
2017 Civic SI
@Rott3n_SI cool build man. Do you have any dyno numbers on your build? Also did you go with 73 or 73.5 pistons? Did you use stock valves and bearings? Thanks in advance. Looking at a similar build.
Rott3n_SI
Pico Rivera, CA
2019 Aegean Blue Civic SI
I’m supposed to dyno tune this morning so hopefully all goes well in a few hours the pistons are JE but I’m not sure what the specs were other than stock compression and stock bearings and valves were used however valvetrain was upgraded Saenz performance rods with upgraded wrist pins were used as well
kshawn
Matthew
Maine
2017 Civic SI
RV6
IL
rv6-p.com
2020 CTR, 2023 Civic Si
Rott3n_SI
Pico Rivera, CA
Sooooo Tuesday I finally dyno tuned with Drob here’s my numbers we hit a issue with the waste gate not letting us build more boost I maxed it at 32psi when we commanded 34 it wouldn’t hit it. Rich is looking into it to see what can be done to get more out of it. Per Drob the turbo and my engine still have more to give but to limited by the wastegate
Honda Civic 10th gen Official RV6 R365 turbo thread AF625D55-9132-4580-B38B-8F93CFE1261B
Honda Civic 10th gen Official RV6 R365 turbo thread 10798C87-E340-4948-822D-24C59BC0AEA5
