Official RV6 R365 turbo thread
RV6
IL
rv6-p.com
2020 CTR, 2023 Civic Si
I didn’t get any emails
Zach your emails are bouncing. It says your inbox is full.
For all of us that are just watching to see first results, what's the problem specifically?... Assume it's something with the wastegate after heat cycle???
One person had their wastegate stick right after starting. We just want to make sure it doesn't happen again. My car and all the test cars have been fine.
So what are you guys doing with your turbos? It was a nightmare trying to install that thing, I really really really dont want to have to do that again. What is the turbo housing exactly?
fuck.. I dont know what to say. He did say that if it was going to happen it probably would have happened already right?
yeah I dont feel comfortable taking a turbo apart, nor do I have the time or money to take all that apart over again unfortunately.
The turbine housing is the part that bolts to your engine. You can swap it with just removing one nut and loosening a clamp. It is not hard at all and only takes about a minute. However if your car is running fine I wouldn't worry about it.
It's the whole turbo minus the guts I believe
Just one part.
To replace housing just the exhaust housing center clamp needs to be removed. Will have to make sure it is clocked correctly as well.
There is a alignment pin so super simple.
Again this was a single incidence. However we just want to make sure everyone is on the same page. It is all part of the BETA process.
Zcfc3dc5
Zach
Wintersville Ohio
2018 civic si, 2002 Acura rsx type s, 2011 Nissan Titan
Just one part.
That’s odd. I’m still receiving other emails. ??‍♂
awsomsauce
Theodore
At home
10 Gen si and 2 6 gen sedans
Hello All,
so it was my unit that got stuck. Thankfully the team at RV6 have been able to find out what’s causing it.
we installed the unit, changed the oil to 5w30, and then burped the coolant system. After all said and done I drove the car gently to minimize boost until the unit had some miles on it.
i went to get onto the freeway and once the car started attempting to build positive boost the check engine freak out show started popping off. So I went back to the shop. We tried clearing the code and it kept coming back.
Then we used the snap on scan tool and the code still kept popping and wouldn’t clear. So Eman tried to open and close the gate and it was really hard.
But now we know the what and why, the fix is being prepared, and sent out. It’s up to you if you want to swap the housings. Chances are if your unit is installed and running perfect you may not have an issue. As for those that haven’t installed the turbo yet I’d say better to be safe than sorry.
Sport-injected
Sport-injected
Scott
Central Jersey
www.youtube.com
Just one part.
It's a tough call, would hate to install then have an issue. Especially since this is my only car and I need to get to work everyday... I'm gonna play it safe and wait it out.
Sport-injected
Sport-injected
Scott
Central Jersey
www.youtube.com
Hello All,
Sorry to hear you had an issue, thanks for sharing!
NicKoLi
Connecticut
2017 Civic SI Coupe
Just one part.
So if my car seems to be running fine with no issues chances are that my unit is fine ? You would be confident if it was your car that it would not happen afterwards ?
NicKoLi
Connecticut
2017 Civic SI Coupe
Hello All,
sorry to hear about that man, no offense but since mine is already installed im hoping its just you :p
awsomsauce
Theodore
At home
Can I ask how many miles you’ve put on the turbo so far?
86salmon
It's Hedley, Hedley Lamarr!
Chucktown, SC
It’s all good. We are the testers so it’s best to find all the bugs for the vendor.
Dude! You are having some luck with turbos!! Hope it's sorted!!!
