Official RV6 R365 turbo Beta thread
kshawn
Matthew
Maine
2017 Civic SI
built with NA performace fuel system
Interesting. Either drob is holding back or that's one stingy dyno machine.
kshawn
Matthew
Maine
2017 Civic SI
Ya the shop i go to has a mustang dyno. Only pulled low 300s @32psi. Granted ign was left alone becuase we hit the boost cycling and called it a day. Glorified wastegate test day.
Well Hopfully a solution comes. Otherwise your options might be limited to a manual boost control system. Or motec.
Rott3n_SI
Alex
Pico Rivera, CA
2019 Aegean Blue Civic SI
At this point I feel to get the power I want I’m just gonna have too bite the bullet and get a big turbo then call it a day
kshawn
Matthew
Maine
2017 Civic SI
If you do. Gtx2867r
RV6
IL
rv6-p.com
2017 Civic Hatch
@RV6 any information when your going to release your drop in turbo?
Turbos are due in mid March. We will be be contacting our production batch 1 list shortly about preorders.
Sport-injected
Sport-injected
Scott
Central Jersey
2019 Civic Si
  • #610
@Rott3n_SI @NicKoLi @awsomsauce @Zcfc3dc5
Ok guys I'm finally installing my turbo this weekend. Any helpful tips for the install? I have new plugs, fresh oil/filter, coolant, titanium downpipe studs and of course all gaskets, lines and hardware that came with turbo.
I think I have all that is needed.
Thanks in advance.
Rott3n_SI
Alex
Pico Rivera, CA
If you have needle nose channel locks those help to block of the coolant line so your not leaking every where. The most difficult one is the little elbow under the turbo that goes to the turbo from the waterpump
Thanks in advance.
awsomsauce
Theodore
At home
10 Gen si and 2 6 gen sedans
Thanks in advance.
Make sure to run 5w30 oil, it’s available at Honda. Also have a laptop ready to change your tune to a new tune. I don’t know what tuner your using but the w1 base map works fine on Hondata. Not sure what’s available on ktuner. I have my plugs gapped down to .020” instead of stock gap which is some thing like .027”. When the stock turbo is removed look for black soot on the turbine side and look for cracking between the turbine blades and wastegate opening. If you see white soot your car is running lean. If you have a crack on the area mentioned in the exhaust turbine, the tune is too lean.
I kept the boost low (under 10psi) for the first 50 miles of street driving and stayed off high speed pulls until after 100miles. It seems excessive but you want to keep the turbo alive as long as you can.
awsomsauce
Theodore
At home
W1 does have its issues and the biggest one is after a while the turbine housing cracks 27won only offers a 1 year warranty and the crack always happens between the wastegate and turbine so be aware of that I have attached pics of my W1 after 8 months of use
This is the cracking I’m referring to.
awsomsauce
Theodore
At home
@Rott3n_SI
[/QUOTE]
So after installing my new RV6 dp/fp on my car I noticed the full boost is hitting later in the rpm range now.
My AFE takeda catless dp I had on my car was a 3” that tapered down to the stock diameter fp. My guess would be that the high boost and back pressure I was experiencing was allowing the turbo to hit peak boost sooner at the expense of lost power on the top end. Now I’m hitting power boost at 4-4.5k but the car pulls like a 9th gen with bad torque steer. Imagine a cartoon car that hits nitrous and it gets squirrelly. Cars 2 Towmater
Rott3n_SI
Alex
Pico Rivera, CA
@Rotten_SI
[/QUOTE]
Yeah that’s where I’m at now noticeable torque steer and power to redline it’s a definite upgrade over stock that being said with my fully built motor and upgraded fuel system I’m thinking I may just go big turbo to make the most out of my setup time and money will tell lol
