Official 10th Gen SI ( DYNO Thread )
2tone
Anthony
Fort Myers, Fl
2017 Civic si. 2006 bmw 325i
What is the consensus on power an Si can push reliably? For example I have a 2015 tuned wrx and most people agree the rods cannot take more than 350tq.
It depends on where the torque is made. Generally(give or take) on a dyno jet:
FBO 93 : 250whp 300tq
Fbo + e40: 280whp 330tq
27won turbo fbo : 295whp 295 tq
27won e40: 330whp 330tq
Big turbo kits can put you up to 400whp and 360ish torque I think could be lower but it’s way farther in the rpm range compared to our stock turbos. Eman did a dyno run at 460 or some other crazy number with meth plus big turbo but he didn’t keep it that hard of a tune on the street so I doubt he thought it’d be reliable. Numbers are just numbers tho and don’t directly equal how fast the car is.
H3llsp4wn707
2015 wrx
2017 si sedan
“Custom” catless downpipe, MAPerformance intake, PRL Intercooler , 93 octane javi tuned 205 hp 255 tq
A lot lower numbers than I expected but he said it was because of the mustang dyno, the guys at the shop call it the heartbreaker dyno and told me it reads about 15% lower than most dyno jets. Javi tuned also recently tuned another si downpipe and cold air only and it made 250/300 but on a dyno jet
I wouldn't worry about numbers. I made 252whp in a '15 wrx stage 2ish (no intercooler) on my tuners old software for his dyno. He used a stock STi to calibrate and it only made 205whp. On the new software my car made 295whp. The only thing that changed was the software on the dyno, and he calibrated it differently.
jkim19SI
Kevin
North Jersey
2019 Civic SI Sedan (Black)
Question, how did you guys manage to dyno the car without going into Limp mode? i did the TCS/VSA light blinking step and the car still goes into Limp mode with all lights on the dash.
  • Like
Reactions: Myx
Myx
Delaware
I'm interested in this as well.
2tone
Anthony
Fort Myers, Fl
I believe the problem is running in sport mode, my tuner made it a dual tune after the whole process. Other than that he disabled something from in the wheel well
Civicsi19
2019 Civic SI Sedan
Remove the ABS fuse under the dash
EkSean
Sean
2019 PWP FC1
You remove the abs/vsa one and it’ll let you dyno in sport with no issues? I’m going to dyno mine but just to see where I’m at so I don’t want to do that whole double tune thing.
turbociv910
taylor
wilmington nc
I could do one pull doing the pedal dance in sport mode then got kicked out. To do multiple pulls i had to remove the abs fuse. I dont use a dual boost tune so i just left the torque the same for both modes.
bbeem
Ben
Iowa
How does this effect street performance? Sometimes when I drift big and go wot in 2nd the vsa triggers and I go into limp mode on the street.
chrispydo
2017 Civic Si Coupe
Honda Civic 10th gen Official 10th Gen SI ( DYNO Thread ) 1991BF02-3BAE-42CA-9C35-F29341B35FC2
Dyno'd today for 271 WHP 323 TQ
Mod List:
- Hondata Flashpro
Powermetric Stage YOLO Tune
- PRL Flex Fuel Kit (currently running E35)
- 27Won Turbo Inlet Pipe
- PRL FMIC & Chargepipes
- PRL Catless Downpipe
- PRL Cobra CAI (Race MAF)
- Fortune Auto 500 Series Coilovers with Swift Springs (9k front, 8k rear)
- Acuity Shifter Cable Bushings
- Acuity Stage 2 Shifter Component Kit
- Acuity Throttle Spacer
Sport-injected
Scott
Central Jersey
www.youtube.com
Mod List:
- Hondata Flashpro
I miss the torque curve of the stock turbo. With the RV6 turbo it's all up top now. Still need to go to a Dyno someday.
kshawn
Matthew
Maine
2017 Civic SI
Honda Civic 10th gen Official 10th Gen SI ( DYNO Thread ) 20210804_153127
451hp and 368tq ? and we weren't done tuning... little misfire uptop on this pull, plugs need to be gapped smaller. 38psi, e35 and meth on this.
IG@KSHAWN207
Mods
*ktuner v2
*FBO
*TSP block, upgraded springs/retainers in the head
*eman SI fuel system
*retrofit R flywheel with stage 2 clutch plate
*PRL turbo kit v1, gtx2867r
*4port M1 meth injection and flex fuel ?
*cortex boost controller/meth controller.
*3" exhaust, turbo->back
Suspension
* whiteline front and rear sway bar
*whiteline anti-lift kit
*front strut bar
* wheels(18x9.5 +45) falken rt615k (265 35 18)
Jes_si562
Jesse
Long Beach
