Oem front Floor brace
Hondanickx
Nick
Belgium
1998 civic hatch , 2018 White civic sedan
So i was reading the eibach install instruction to install their front swaybar ,when i noticed they removed a brace that i never saw before.Upon further research i noticed this is a floor brace that only comes on the Civic hatch EX ,LX and sport. It's mounted partially on the heat shield and on the chassis with 4 m10 bolts.
I noticed the bolts and the space is already there on all the other models ,allthough they might be a bit shorter.
This is another nice oem bolt on brace to further increase the cars rigidty.
Floor brace is part number 74178-TEA-T00 Cost around $7 - $10
Bolts are part number 90114-SM4-000 cost around $2.64 -$3.74 each
Part number 14 & 9
Hondanickx
Hondanickx
Nick
Belgium
  • #3
Nice so it's only on the hatchback then.
TypeSiR
Ridiculosaurus
1.5T Civic, CTR, MX-5, Fit
Nice find! Watching this closely. Can any sedan Si owner comment on whether the brace is factory-installed? If it is, then it bodes well for adding to the mod list for lower trims (non-hatchback). Thanks!
Hondanickx
Hondanickx
Nick
Belgium
  • #5
I checked the online Honda Parts again and it's not on the regular sedan,coupe ,sedan si or coupe si .Its on all the hatches.On the type r i can only see the bolts listed ,the brace itself not.So i'm not sure the type R also has this .It's something that's only on the hatchbacks.Would be a nice upgrade for all the sedans and coupe.
Kenny
Richmond,TX
17 Civic Type R
Type R does not have any under body brace. But Cusco offer an aftermarket brace as picture below.
The Vyzitor
FYI if you use the Type R exhaust on your hatchback, the front resonator does not allow for this brace to be installed.
ycehcky
Matt
Virginia Beach, VA
2018 Civic Si
Update. I checked under my car, and it looks like there are holes there but no threads. I do not believe this will work on sedans.
LightX
Andrew
2018 Civic Hatchback Sport
I bought the Thermal R&D Exhaust. It came with a thick metal brace to replace that piece. Definitely a nice addition and also extends lower to give exhaust room etc..
integra15
Ann Arbor
2017 Civic SI
This will not fit sedans. The holes are not threaded as mentioned. Additionally for the SI at least, the plastic shielding covers the holes completely.
