OEM ASEAN Clear Side Markers + Sylvania Amber LED Bulbs
spnewera
2016 Civic EX-L Black
I tried to install them but ended up giving halfway.
I'm willing to sell both for $90 including shipping and paypal invoice, I just want to make up what I lost.
RallyeRed
Arizona
2016 Honda Civic Touring
What are you having trouble with? Maybe I can help if you would rather keep them.
spnewera
spnewera
You have to cut off the two nubs to get it to fit to the ASEAN's housing-- I don't really have the tools. I tried with an xacto knife and it wasn't working.
Also, I don't really know how to remove the markers from their housing. I was so rough with a screwdriver that one of them is actually kind of loose when I put it back. I can't even take out the bulb from its housing.
RallyeRed
Arizona
Yeah, it sure isn't easy. What I ended up doing was taking a razor blade, since I didn't have an xacto knife. I just started at the tapered end, pushing down pretty hard. What I would do is push down and once you have cut into it a little, push outwards to snap pieces of the plastic off.
And I also had a hell of a time with the stock side markers, and I also damaged mine trying to get them out. There is a tab you have to push and it should just fall out. The stock side markers are built quite cheaply compared to these ASEAN side markers, so it seems that tab can be damaged and bent to the point where it won't fit properly if you put it back in. Also, I'm not sure how you were going about it, but I removed a piece of the front fender lining in order to get access to this tab on the side marker.
Let me know if I can be of more help, if not good luck with your sale! Someone will pick these up, they are awesome!
jmat
2016 Civic EX-L
Don't sell them! I had a B of a time installing as well, then to top it off I had to remove them both again and turn the bulbs around. I wanted to go mad haha. Be patient and the reward will be yours!
Brisco
Matt
Kitchener
2018 Aegean Blue Civic Touring
I’m dredging up an old post here but I want to set somebody’s got to help me
