No boost after downpipe install
Fc1_Tate
Farrah
Virginia
2020 Civic Si
Gonna try and be as specific as possible but I have no problem answering questions. I installed the PRL Catless DP a few days ago and noticed once I started driving I’m only making around 8psi max instead of 21 I believe (TSP stage 1.) There weren’t any issues with install, I reconnected the O2 sensor and cleared it with Ktuner. I didn’t reuse any old gaskets so I’m wondering where I should start. Checking charge pipes? I’ve already taken off the DP and reinstalled to make sure it wasn’t my error. Thanks in advance for any help
booost
Palm Beach, FL
2021 Honda Civic Type R
Are you on the right map?
Sounds like a potential boost leak though, can get a boost leak test done and it should show you. Check anything that was touched.
Fc1_Tate
Fc1_Tate
Farrah
Virginia
2020 Civic Si
Believe so. Reflashed to stock then back to TSP 1 on map 3. I’m not too mechanically inclined but enough to know what I’m doing, would I be able to do a test at home?
booost
Palm Beach, FL
Ya, most likely a boost leak somehow or at least it sounds like it. Just go back through and make sure all couplers and clamps are tight on your intercooler, turbo, hoses, etc... anything that would have been touched or could be effected. You may end up seeing a loose hose and that solves it.
There's a lot of videos on how to do it yourself. I personally have a performance Honda shop near by so I bring my car there when I need to do it.
Fc1_Tate
Fc1_Tate
Farrah
Virginia
2020 Civic Si
Thanks for the help I really appreciate it !
Fc1_Tate
Fc1_Tate
Farrah
Virginia
2020 Civic Si
UPDATE: This could be completely off but I figured I’d ask, could the clutch be going out? Would that be the reason for loss of power/boost.
WhiskeyTango
Matthew
Milwaukee
2019 Civic Type R
It's possible you are confusing clutch slip for a loss of boost. Do your rpms go up quickly without the car really moving?
Fc1_Tate
Fc1_Tate
Farrah
Virginia
2020 Civic Si
I’m kind of just running through everything I can think of. But yes they do
Fc1_Tate
Fc1_Tate
Farrah
Virginia
2020 Civic Si
Fc1_Tate
Fc1_Tate
Farrah
Virginia
2020 Civic Si
Best video I could get and it was barely wanting to move even then. Can try to take a better one tomorrow but not sure if the car will move much farther at this point.
Fc1_Tate
Fc1_Tate
Farrah
Virginia
2020 Civic Si
Have you tried to drive it with the stock DP back on?
I have not. I thought about that earlier in the day but where I’m at now I don’t have it.
