Maf is calibrated from me to 0 zero with help (@varge )Did you custom tune yourself or did you bring it to a pro tuner?
Any update?
Any update?
I checked your logs and noticed that you have very high iat temps. Knock control is reacting to this probably. What kind of fuel are you using?
Did you have the same behavior with the starter 18?
Here in Greece is 100ron in pump i don't remember the equivalence in US .
You call high both iat's?
I have not tried other maps with artificial off.
As an update I have tried to use the base map to copy paste boost etc and reflashed but same old song!
Ambient temp around 20 Celsius.
Note: stock I/C, mishimoto intake
IAT2 is not the problem. I’m custom tuned for CAPTS Stage 2 turbo, which is TD03 hybrid, targeting peak boost of 23.5 psi from 4000 rpm, hitting 50 celcius IAT2 & my knock control sits at .49. Only after 3rd pull I saw my knock control went up to .58.That boost is probably too much for such a long pull with stock intercooler. You are at over 45 degrees iat 2
Try with 18 psi
yes ignition base changes have been made but (i will check to be super sure) we are talking about 2-3degrees actual ignition.IAT2 is not the problem. I’m custom tuned for CAPTS Stage 2 turbo, which is TD03 hybrid, targeting peak boost of 23.5 psi from 4000 rpm, hitting 50 celcius IAT2 & my knock control sits at .49. Only after 3rd pull I saw my knock control went up to .58.
@markon : did you make any changes to your ignition base? I’m on initial support & I can do basic engine tuning. The only missing features are on the fly map switch, boost by gear, & flex fuel in non beta codebase.
i've often reached 0.8 with 21 psi starter map after a 3rd-4th-5th (till the limiter) pull with stock intercoolerIAT2 is not the problem. I’m custom tuned for CAPTS Stage 2 turbo, which is TD03 hybrid, targeting peak boost of 23.5 psi from 4000 rpm, hitting 50 celcius IAT2 & my knock control sits at .49. Only after 3rd pull I saw my knock control went up to .58.
2-3 degrees of actual ignition could have significant effect.yes ignition base changes have been made but (i will check to be super sure) we are talking about 2-3degrees actual ignition.
Did you activate disable artificial knock increase feature? If you did, you're having a real knock & that is not because of high IAT2 temperature.i've often reached 0.8 with 21 psi starter map after a 3rd-4th-5th (till the limiter) pull with stock intercooler
I used TSP stage 1 for Non SI CVT when I used stock IC. Peak boost was 24 psi. After 3 pulls, my knock control went up to .80 but we didn't have feature to disable artificial knock control. IAT 2 was 58 celcius with 34 celcius ambient temp.
I didn't explain well probably. I had those movements when the disable wasn't available yet!2-3 degrees of actual ignition could have significant effect.
can you pls suggest any reading regarding iat corrections?I didn't explain well probably. I had those movements when the disable wasn't available yet!
Anyway knock control can raise even if you have high temps.
I would suggestto set iat corrections in ktuner and try again
