New Battery already?>
topher_fc3
Topher
Las Vegas
instagram.com
2020 Civic SI Coupe
So what batteries have y’all upgraded to?
I’m running a 600watt amp, and I also killed the battery on accident one night by leaving the accessory power on. This morning it took longer to start than normal and it was only in the 40s so I’m thinking I’ll get ahead of a future headache and upgrade sooner than later.
SDAlexander8
Steve
Indianapolis, IN
I do hear good things about the costco interstate batteries.
Seth_FC3
Seth
Miami
2020 SI coupe
Trust me, these batteries suck. About 2-3 months ago I had to take it to change the battery after owning the car for barely a year. I couldn't believe it either, but ofc it was covered under warranty.
BrandonSmith
The Greatest Country on Earth
2016 Civic EX 2.0L
Dude you really think a dealer service center makes so little money we swap out your original battery for an old one?! My god. People are impossible these days.
The 56k miles is why it died. I see them die all the time out here with 4K miles. 15k miles. 1-3 years from new is normal. The factory pays for a new battery if within 3/36.
Crazy thing is you paid 181 for aftermarket. The Honda OE Battery is 155 installed out here. ?
I should feel lucky I got 4.5 years and 103,000 miles then! and only paid $75+tax for an Interstate battery at Costco!
The Costco Interstate batteries are not the base model battery either. They are a step-up from a standard battery (the "MT" line of batteries) and have 500 CCR compared to Honda OEM 425.
This is battery Costco carries (MSRP $145, Costco sells for $75): https://www.interstatebatteries.com/products/mt-51r
TypeX
NJ
ASPEC RDX
My car is only 23 months old the battery is shot. < 20K miles. Sad. I'm keeping it on a tender until I have a paycheck again (soon).
Go to homda if its marginal or bad ( in warranty) they will replace
Zswiat
Zach
Cincinnati
2019 civic si sedan
My battery had a cell go bad after about a year. The dealer replaced it no problem. It was just a pain to deal with on a car that didnt even have 15,000 miles.
Juddtastic77
Judd
2019 Si sedan
Mine went bad at 40k... the dealership warranty was 3 years/36,000 whichever came first. I’ve only had it 20 months. Needless to say, went to autozone, spent my $200 and it’s done. It sucks, but it’s done. I have no aftermarket electrical stuff
MONK13
MIKE
TEXAS
2019 CIVIC Si
My battery just DIED went bad at 2900 mi (20 months old). Honda replaced it under warranty and tried to upsell me on "battery maintenance" as the old battery leaked acid on my cables (I had to pull of my strut bar before taking it in so I know there was no acid leak) - Stealerships
BTW the best car battery hands down is sold at AutoZone: Optima
CDjunkie
Birmingham
04 S2000, 17 Si
mine went stone dead @ 32K, about 2 years old. (after having passed the dealer battery test about a month prior)
Design
Southern California
09 MS3, 17 ABM Si Sedan
It's widely known that Honda had a bad batch of batteries in the 2016-18 Civics, and some early 2019s. Most have come back with partially failed cores. They are hard to diagnose if you drive frequently, as the surface charge between trips is often enough to mask larger issues. The OP's issue likely surfaced while the dealer performed their standard multi-point inspection, and likely drained an already weak battery.
I generally replace mine with a comparable Costco battery. I believe they contract directly with JCI which is one of the largest suppliers of automotive batteries, IIRC.
Mrparis
Paris
honda
I rath
I rather go with after market... honda battery seem to go quick... I never had a honda battery in my life.. all the other batteries i had lasted 5 years easy.... there is only two battery companies in usa.. Honda gets their batterys from overseas...
tacthecat
Cheshire, MA
'12 Civic Si Sedan
Get use to it. Average life of a battery for newer model cars is much shorter (now 2-5 years; use to be 5-7 years) for a number of reasons - much higher electrical load, heat in engine compartment, smaller battery size, etc, etc. Lots of Battery Sellers claim otherwise but with only 2 or 3 battery manufacturers selling in the USA, best bang for the buck is cheapest you can find for your needs. A number of owners are seeing this phenomenon for the first time because they used to trade vehicles every few years - not anymore.
PS - Honda batteries are made in the USA by Johnson Controls - one of the main builders remaining in this environmentally dangerous, but necessary, business.
mr.2018_SI
Didier
Rockville, MD
2018 Honda Civic SI
I just tuned my car for the first time. Battery drained enough while in accessory mode flashing the tune that it wouldn't crank after the flash. Had to jump start it. Couple days later, I switched from a base Ktuner tune to TSP Stage 1 and same thing, needed a jump. Guess I'm going battery shopping soon.
jason510
Jason
2019 Civic Si Sedan
Thank you for chiming in. When it comes to service on my Si, and the three previous Hondas I've owned, I've had mostly good experiences. I think there's too much competition out there for them to try and screw you, especially in SoCal with the number dealerships in the area. Dealerships are not non-profits, they are there to make money. Yes, I've been given false information, yes I try and get services sold to me that I don't need, but that's partly on me to do my research and educate myself on what my car needs and when it needs it. For example, knowing what the maintenance minder is and how it works or learning how to replace or clean things like the air and cabin filter can save you a considerable amount of money.
If you had a bad experience, write an email to the owner of the dealership or express your not being satisfied in the survey they send. Giving a black eye to every Honda dealership because of a bad experience is immature in my opinion.
saz468
Stan
Mine lasted two years but that’s a Florida thing batteries and tires
got a new one under warranty
