NEW AC CONDENSER LEAKING TSB 19-091
Spacesloth
Wisconsin
2017 Honda Civic SI
Has this whole AC issue been fixed with the 2020 models I am debating between a used 17/18 or a new 2020 si.
I can’t speak to the reliability of the 2020 AC, but they have revised some components over time so I’d get a 2020 over used. In addition if you live in cold climate they revised the 2020 rear suspension shock mount to fix the clunking. Also addressed the A-pillar rattle, updated radio with a knob and newer software. Most importantly it’s new and you know it hasn’t been beat on or tuned previously.
Darthus
Oakland
Civic 2016 Touring
Update: a leak in the evaporator core. A PITT to replace being under the dash and firewall. Total cost to replace is around $2K.
At 54K miles, Honda covered 90% of the cost. And they proactively replaced the condenser under the extended warranty (a relatively cheap part) since the system was open anyways.
Although I'm a bit disappointed in the failure, I understand these things do happen. What matters is both the dealer and Honda stepped up and took ownership.
Total cost: $211.98.
Hey Design,
Just curious about your case. I'm at like 44K miles and Honda corporate said they would only cover the cost of the Condensor, not the Compressor and Clutch ass'y which was quoted at 2K parts and labor.
It sounds like you were able to get Honda to cover repairs outside just the 10 year warranty on the Condensor (which is all they offered me). If so, how did you manage that?
I just drove 6 hours from Southern to Northern California in 100 degree heat with no AC and all windows down. My wife had to hug bags of ice to stay cool.
Also, what do people think about me just getting the condensor fixed, having them recharge the coolant and dumping this lemon by selling it to a dealer? Would a dealer be likely to do a full AC check to know there are additional issues or be able to obtain that assessment from Honda?
rwt
Richard
Hoffman Estates, IL
2016 Civic Tourng
The condenser on my 2016 Civic touring was replaced in Sept 2019, still under warranty. Blowing hot air on the driver's side like so many others. Now it's June, 2020, car still has under 36K miles but is now more than three years old. Car is blowing hot air on the driver's side again. Thought it would still be under the new 12 month warranty for last year's repair but now they're saying it's the evaporator that's broken and will cost $2600 to repair. I can't believe the same problem is being caused by a part independent of the part last year and yet causing the exact same problem. This is my second Civic. Don't think they'll be a third.
frontlinegeek
Jason
New Brunswick, Canada
2010 CRV, 2017 Civic EX Sedan Honda Sensing
Pretty sure I would fight that one.
But to your point, for sure, at the least, never get another Civic or even Honda if that is how your local dealer is going to treat you. The automobile ownership experience is a total package thing so if the service and warranty experience is a royal pain, then why even give them your business to start.
It makes me sad seeing all these bad dealership experiences...
curtngel
Calgary
2016 Civic
Keep us posted on the evaporator replacement and how well - or how poorly - your dealership and / or corp Honda treat you.
I was told today that my evaporator is done on my 2016 Civic Touring with 110k km (65k miles), which I bought new late Oct of 2016. I started hearing the distinctive crackling whooshing air sound from the HVAC unit at start-up, along with intermittently crappy a/c performance 2+ years ago. We don't need a/c for more than 25 - 35 days a year where I live, and so I wasn't motivated to get it checked out until I had total a/c failure in June of 2019. At that time, the car was less than 3 years old, but out of warranty due to mileage of around 53k miles. Two a/c recharges later - thankfully one free of charge, and the other at a reduced rate - and they've now determined its the evap unit that's leaking, not the condenser or compressor. Regardless, its ridiculous how many issues plague the GenX Civic's a/c system.
JohnnyL
2019 Civic Coupe EX
can't fault them for a manufacturing defect on a product they didnt make though. Kind of sad it took 4 years but here we are and they are making it right
Yes, but so it seems they kept using the same junk parts for 3-4 years. I had a 16 that failed and now I have a 19 that was fixed for the same problem a week ago.
Design
Southern California
09 MS3, 17 ABM Si Sedan
Hey Design,
Sorry, I'm only just seeing this. I think the dealer has the ability to influence the outcome based on customer history. In my case, I've taken the car to the dealer for every oil change since I bought it from them (I bring my own oil). That, combined with a history of positive survey results, "could" have influenced my case.
I don't know if this was covered by Honda Corporate or a dealer goodwill credit. Regardless, it pays to maintain a good relationship with the service department, IMHO.
zroger73
United States
2019 MX-5 Miata GT-S, 2020 CX-5 Signature
It's usually the other way around - Honda influences the dealer. :)
I'll bet the house that Honda covered the cost of this repair. Loyalty means very little these days.
Design
Southern California
The way I understand it, Honda looks at customer history and accepts feedback from the dealer on any additional information not documented. I did mention to them that I had noticed a variance in driver/passenger temps as early as 30K. But did not consider it an issue until this year when it began getting hot outside.
Looking at my invoice, Honda was indeed the one that covered it. 90% on the evaporator and labor, 100% on the condenser.
