Need rims for Winter tires
GTA1977
Martin
2017 Honda Civic Si
I picked up some Michelin Ice-X 215/50-17 winter tires. Just wondering if 17" x 6.5" and 5 x 114.3 bolt pattern rims off a Rav4 would fit? Thanks.
SDAlexander8
Steve
Indianapolis, IN
I think they’ll fit. Sidewall will be bulging out a bit. Most Honda 17” wheels are 17”x7”. You’ve got the right size tires.
vieux georges
georges
Saint Jerome ,Quebec, Canada
2017civic si coupe
I' d be surprised if 17s would do on an Si. The front calipers will rub.
I bought 17 mags ( 2008 Si ) on Kijiji and I had to work on them with a grinder.
You can see them on page 31 of the thread: What' s your SI looking like today ?
SDAlexander8
Steve
Indianapolis, IN
17s will fit the Si. That is the smallest you can go and have it fit around the front calipers.
GTA1977
Martin
2017 Honda Civic Si
Will these wheels fit 215/50/R17 tires on a SI?
Honda Civic 10th gen Need rims for Winter tires Screenshot_20191211-202350_Chrome
bnb0523
2019 Honda Civic Si
Mine has the 2013 Si wheels and they sit flushed but fits perfectly.
Honda Civic 10th gen Need rims for Winter tires IMG_20191115_154159
_dc_
Toronto, Canada
2017 Civic Coupe Touring
You'll also need to check the center bore. The Civic center bore is 64.1mm. Anything smaller won't fit. If it is larger than that, you should use hub rings.
EDIT: Looks like Toyota uses a 60.1mm center bore, so if that is the case, the RAV4 wheel won't fit onto a Civic, as OEM wheels are typically hub centric. Check the center bore size before you buy.
GTA1977
Martin
2017 Honda Civic Si
Perfect, thank you for your great response. You saved me from a costly blunder.
