They should fit... depending on how low you are will determine fitment but those tires should fit the wheel, if anything size up to 235 if you want some more meat on them when you get tires next. But like I said how low you are will determine needing camber and if you have to do anything with the fenders for them to fit without rubbingHey Everyone,
I am planning on buying the Enkei RPF1's in white they are 18x9+35 offset and currently I just bought some new tires that i want to transfer over on them, the tires i have are 225/40/18, i dont know much about tires and wheels sizes will they fit? Will they look weird? Keep in mind that i'm on coils.
Appreciate it! Thank you for your help man!They should fit... depending on how low you are will determine fitment but those tires should fit the wheel, if anything size up to 235 if you want some more meat on them when you get tires next. But like I said how low you are will determine needing camber and if you have to do anything with the fenders for them to fit without rubbing
