My Street and Trackday build 1.5T
carfun
Hong Kong, Bangkok, Shenzhen
www.gt-tune.com
civic 1.5t, EVO9, RS4, GTR R35
Here is my street and trackday build for civic 1.5T MT.
As we know not many parts available for our car, some just need to modify and put it :)
Suspension
FA1 Tein monoflex + swift spring
Front using some E class spring don't know which model lol
Wheel and Tires
AD08R + Aspec 18 x 8.5 Forge wheel
Brake
AP Pro 5000R + 355 disc + Race brake pad from my EVO9 used
Wheel nuts
Titanium wheel nuts
Exhaust
Middle to end stright pipe from Aspec
Guage
Defi turbo meter
Dyno Test
98 octane pump gas. boost 24 psi.
The turbo cut off 25 psi, I think reach the limit of turbo can't push more. Will check in this weekend after change front pipe see what result we will get.
Test drive
Boost 22 psi (1.5 bar)
Cusco fully installed:
HKS Blow off installed:
LSD
This LSD special made for our 10th Civic MT. My car is first in the world install this lol.
Suspension - BC racing
Finally the long wait, thanks BC racing sponsor me this set of DR track model.
Racing Radiator
Stock size
Bigger size
carfun
carfun
www.gt-tune.com
  • #4
A lot of cool parts. Is that a bypass valve on the exhaust?
Yes it is bypass value, can have comfort mode, sport mode and race mode with remode inside car.
DrwMDvs
NE
2017 WOP Civic Si Sedan, 2000 Honda Civic
Wow! Those wheels.... :yes:
Props and Keep up the good work. Someone has to be the first. I'm going to have such a bad itch to mod when I get a new car, but. must. resist. temptations.
carfun
carfun
www.gt-tune.com
  • #8
Every car I got, all mod... Can't stop the itch lol
Design
Southern California
09 MS3, 17 ABM Si Sedan
Very creative on some of those parts - especially the suspension. ;) Couple thoughts:
- Interested to know the specs of the springs if you can get them (rate and length, or the vehicle they were designed to support).
- 25 PSI seems a little past the operational limit of a typical single scroll TD03. Though Honda has known to get creative in their specs. :)
- It seems we're still learning how to dyno the CVT on this platform. And although the numbers are technically inflated on the Dynapack, the curve looks good IMHO. Does your tuner have any AFR readings?
- Props to you and your tuner for including a baseline on the dyno. :cool:
Troy Jollimore
Halifax, NS, Canada
2016 Civic Touring, 2018 VW Golf
You can go to the operational 'limit', but you're already in a place where your turbo is producing more heat than power.
If you're that serious, surprised you didn't axe the dual exhaust in favour of a single to lose the weight.
carfun
carfun
www.gt-tune.com
  • #11
Thx :) Suspension we just testing, first think of lower spring. We take out spring and compare with some old spring we have in shop. The front is from E class which look similar and sure is harder than original. It is not good doing this way :), but it is only solution at the moment. BC racing they will give me DR type coilover 1 set for testing later.
The AF around 10.xx for 25 psi.
The base line is 191 hp, car already change exhaust. Gain about 20 hp from stock. Will change downpipe this weekend and dyno see if gain more hp.
carfun
carfun
www.gt-tune.com
  • #12
I want the single exhaust but the exhaust company give this for free and they prove their exhaust gain 20 hp in dyno with my car. I feel the exhaust too quiet even in race mode. Hopefully after change downpipe will will have more noise :)
AegeanT
London, ON, Canada
2019 Honda Civic Si, 2016 Honda Civic Touring (sold)
Someone has to be the first to push the limits of a new car. People did it in the past with any car, why not this one, right? It looks great and the numbers are awesome. Keep it up!
xjoshuax89
Josh
Maryland
Sweet stuff! Keep doing what you do!
