My Black Stone oil analysis result on 2017 Ex HB
biosses
Japan
Civic
Here is my Black Stone oil analysis for my 2017 EX HB at 30,000 miles. I have been using Mobil 1 oil and oil filters since day one, have been changing the oil religiously at 30% oil indicator. Only recently i switched to Pennzoil and OEM Honda oil filter. What do you guys think?
Honda Civic 10th gen My Black Stone oil analysis result on 2017 Ex HB oil analysis at 30k miles
parshisa
Texas
Civic X Hatchback LX
Fuel dilution is well over 5%, BS methodology of testing for FD is faulty. Low viscosity due to fuel dilution. Going to 5w30 is strongly suggested to offset for loss of viscosity. Many have switch including myself and having great results. Wear metals are equal to those I had with 8K miles run with 5w30.
hobby-man
GTA
I'm by no means an expert but between the flash point, viscosity, and fuel dilution metrics it does seem to be a bit thin to me. Obviously not to the point where your motor is wearing abnormally, but something to consider.
biosses
Japan
Civic
What do you suggest? switch to a thicker oil?
The Vyzitor
Yep. If you’re uncomfortable going too thick, there are some “thin” 5w30 oils out there. Notice on your report, it gives the range for 20 grade up to 9.4cSt? I run Valvoline Modern Engine 5w30 because it is on the thin side for a 30 grade. 9.8cSt@100°C according to their data sheet.
biosses
Japan
Civic
i don't know much about motor oil, i just use the oil grade stated by the manufacture.
NotSerious
Me
GreatWhiteNorthEh
2018CivicLXSedanCVT
Maybe start changing your oil at 40% or 50% instead of 30% instead of messing with different oil grades.
The Vyzitor
all the specifications are usually available on the manufacturers websites. Usually in a PDS (Product Data Sheet) or technical data sheet.
bobistheoilguy.com is a fantastic resource for learning about oil. There is far more to oil than the numbers on the bottle.
https://www.bobistheoilguy.com/motor-oil-101/
GreaseCrow
2018 "Clifford" Civic Hatch Sport 6MT, 2015 Civic EX 5MT
I got my Civic Hatch about a week ago and checked oil today. Turns out the dealership didn't change oil as it was black and over the max line on the dipstick. Also reeked of gasoline so I got it swapped asap. Using 0w30 Mobil 1. Gonna change at 40% and probably get an oil catch can.
biosses
Japan
Civic
yea...i might need to change it at 40% too, I thought about oil catch can, but do you know if it helps with oil dilution?
biosses
Japan
Civic
No. It reduces oil sludge buildup on the back of the intake valves.
This has not been a big problem so far on Civics.
i just google this actually, right before your message...yeah...it doesn't do anything for oil dilution
Civics4Ever
Rally Red EXT
Gene
Illinois
How many oil changes so far? 3?
biosses
Japan
Civic
I don't remember how many total. But i change oil at 30% each time, have been using only Mobile 1 0W-20. The last change @ 30k mile was early ( at 60% MM), because i suspect i had oil dilution.
The Vyzitor
The easiest thing you can do to combat oil dilution is change your oil early. Which can be done in your garage with a fluid pump in a matter of minutes. Without lifting the car. Just the oil. No need to change a filter at low mileage.
Just pump out the diluted oil. Refill with good oil. Carry on. Don’t reset the MM. Use the MM to remind you when to change the filter.
Honda Civic 10th gen My Black Stone oil analysis result on 2017 Ex HB 2FB9D017-D01D-4571-83BA-CDAB0F6D883F
