(Motor blew)PRL turbo kit with meth injection
hobby-man
GTA
2018 Sport Touring Hatchback
Reviving an old thread to tease a current project. More coming as spring approaches 😉
I was thinking about setting up port meth injection once I get my motor back. I've seen some concerns though about drilling/tapping the plastic manifold and removing those support ribs in the plastic.
kshawn
kshawn
Matthew
Maine
2017 Civic SI
  • #272
kshawn
kshawn
Matthew
Maine
2017 Civic SI
  • #274
kshawn
kshawn
Matthew
Maine
2017 Civic SI
  • #277
hobby-man
GTA
If it came down in price by like $300.
I looked at it as well, probably 8-900 CAD before import fees to get it to my door. Pretty steep for something with nearly no reviews, dyno plots, or airflow plots.
ManitobaSI
Scott
Manitoba, Canada
2017 Civic SI
That meth plate is pretty cool. I am new to the meth situation. I need to read more on it. Is there much to be gained by injecting it into the charge pipe. I have the port on my 27won pipe.
hobby-man
GTA
I have mine set up that way right now. Didn't get as far as tuning it before the motor went though lol. It's a very common way to do it and would definitely work. The issue is when you get to high flow rates, you'll potentially run into uneven distribution among the cylinders. That's were port injection shines.
ManitobaSI
Scott
Manitoba, Canada
2017 Civic SI
Okay a few dumb questions now.
- how much hp do you get?
- do you have to tune?
- is meth preferred over nitrous?
- do you just hold a button while it sprays and that is the duration of your increased power?
this is very interesting stuff. Sorry for the questions.
hobby-man
GTA
I've seen 50-80 thrown around but I think it comes down to how aggressively you tune
Tuning is required for any hp gain. You can just spray without a tune. It will actually slightly lose you power according to DRob but it has many benefits in dropping IATs and knock prevention even if there's no timing advance tuned in
I'm really not sure on this one
Most kits have a progressive controller. So mine is tapped into manifold pressure. It begins spraying at a minimum flow rate at 5 PSI for example. And it's set to top out at 24 PSI. So the flow rate just gradually increases linearly between the start and end setpoints. It's fully automatic, no BOOST button :p
CAPTS
TY
Malaysia
www.facebook.com
10th Gen CivicX CVT->MT
AFR will be RICH & power will be lost not due to no ign advance.
YES tuning is required & YES it is BEST to have failsafe in place.
Like i said OP will be ahead of me while i'm waiting on other parts & to figure other stuff/add-ons out & also the delay due to partial lockdown here in my country because of covid cases going up.
Looking fwd to see it in action & it does really look familiar haha, well done OP , pls keep us updated.
*NOT trying to jack the thread but no point on starting a new one, sharing some experience & work done so far*
Ty3366!!
Tyler
Canton Ga
2020 Civic SI
@kshawn crazy man! Excited to see what crazy amount of meth numbers you make without a port injection system! GTX2867 ||? Or 60? Very interested in peak WTQ specifically and power band range.
kshawn
kshawn
Matthew
Maine
2017 Civic SI
  • #285
Hahaha sooooo. 4th gear blew last night.
Mods on hold now. The hunt has begun for a trans.
