Motive Power bleeder (for brake and clutch) setup for 2016+ Civic hatch, sedan, coupe
das borgen
Richard
Columbus, Ohio
E36 M3, Ducati 748, '17 EGP Si Coupe
I had a power bleeder I got years ago for my BMW and I wanted to also use it for my Hondas.
I cut the air line and got a female quick disconnect coupler for the bleeder side and 2 males for the master cylinder reservoir side so I could easily go between either German or Japanese car.
The Honda cap, I got from Amazon and it fits perfectly on basically any Honda brake master cylinder, having tried it on my current gen Civic Si and CR-V.
https://www.amazon.com/dp/B01MYXAXS5?ref=ppx_pop_mob_ap_share
I have always bled my cars at 12 to 15psi and I'm able to easily hold that pressure with no leakage.
ETA: If using this type of bleeder, I strongly recommend you keep an eye on your reservoir fluid level. I typically just unscrew it after bleeding each caliper to top it off and move to the next caliper.
The power bleeder does have a straw that can pull up fluid from inside its built-in reservoir to keep the master cylinder reservoir filled as you go, but I personally don't like using that feature available. I'd rather control the fluid level in the way I described.
You can also use this tool to bleed your clutch slave cylinder. I've done it on my BMW, but I prefer to just gravity bleed the clutch system as it seems to work perfectly fine already
Honda Civic 10th gen Motive Power bleeder (for brake and clutch) setup for 2016+ Civic hatch, sedan, coupe IMG_20200711_160609
Honda Civic 10th gen Motive Power bleeder (for brake and clutch) setup for 2016+ Civic hatch, sedan, coupe IMG_20200711_160751
parshisa
Texas
Civic X Hatchback LX
That is an awesome setup, exactly what I was looking for. Can you post a link to the quick disconnect and male connectors? also, what is the size of the airline you've used?
das borgen
das borgen
Richard
Columbus, Ohio
parshisa
Texas
das borgen
das borgen
Richard
Columbus, Ohio
You're welcome!
JT Si
Place
Car
I can never get the clutch master cylinder to bleed properly even between using traditional pedal-pumping and a mityvac. I just ordered the Motive bleeder and the cap you linked in hopes it will make quick work and take care of the soggy pedal.
I hate bleeding the clutch master cylinder.
Friction
Si
This gave me an idea... I've been thinking of buying a power bleeder but I have a rarely used roundup pump bottle. I may rig it up similarly and either not worry about a pressure gauge or I may drill a hole and add one to the bottle, or inline on the hose.
st4xor
Eric
Washington DC Metro Area
2020 Civic Si Sedan
I had a power bleeder I got years ago for my BMW...
To anyone who doesn't already have the Motive bleeder laying around, it may be more cost effective and/or less headache to just get the matching CTA bleeder and skip the custom tubing and quick disconnect.
I haven't used it yet, but I got the updated design with the 10' hose when I ordered from this listing on Amazon:
https://www.amazon.com/dp/B004X4Z6XK/
pinhead66
Bay Area, CA
Happy to report that my old Motive bleeder 0107 has now been converted for my Hondas. Test fitted it on my Odyssey tonight and it held 15 psi with no leaks. Left it on for over 3 mins with no drop in pressure. My setup was a little different as i had to use a 3/8” barbed splicer to connect my original hose to the new 3/8” id hose that leads to the CTA 7030 cap. Very happy this all works now. Now I’m womdering why Motive didnt just make a proper cap for Hondas in the first place. Big thanks to OP.
Honda Civic 10th gen Motive Power bleeder (for brake and clutch) setup for 2016+ Civic hatch, sedan, coupe 31751481-8FCC-4B1E-A91E-F302A5914EAB
das borgen
das borgen
Richard
Columbus, Ohio
I'm glad to see it worked for you!
Nice Odyssey!
JT Si
Place
Car
I finally received my motive power bleeder today, along with the Honda cap. I'll be using it to re-bleed my clutch master cylinder. Here's hoping it is effective and actually gets me the firm pedal. No amount of mityvac and pedal pumping could.
das borgen
das borgen
Richard
Columbus, Ohio
Try doing 2 or 3 ABS stops on the street and then go bleed the system
dellyjoughnut
Los Angeles, CA
Toyota 4Runner, '19 Civic Sport Hatchback
I never knew this thing existed till I started playing the game Wrench showing a power bleeder is available in game.
