davidgostbo
Could we get a video on how it sounds?Out with the old, in with the new:
takes a little bit of wiggling to get out, it sits on a rubber post/dildo looking thing that centers it
my airbox didn't line up exactly with the stock mounting holes of the old airbox. I needed every mm of play that the mounting brackets had on the mishimoto airbox to fit it.
mishimoto MAF housing didn't fit the cutout in their airbox exactly, had a ~3mm gap around the hole to the air filter, but when the air filter is mounted and butted up against the inside wall of the airbox it covers up the gap decently enough (guess i should've taken a picture of this)
finally I accidentally destroyed a small washer using it on the rubber isolator to radiator bracket mount (that nut needs a big washer, missed that in the video), good thing there was an extra screw and small washer (unless I missed a bolt in the airbox lid, but three seemed to do the trick just fine)
Other than that install was easy and the fit and finish are pretty good, kudos mishimoto.
and did you hear any difference between stock and this?
