Mishimoto 1.5L intake on stock tune
charlesrocket
NYC
www.charlesrocketphoto.com
2017 Hatchback EX
how safe to run mishimoto's intake on 2017 ex hatchback in stock tuning? don't want to reflash before warranty runs off. "This unit is a complete bolt-on part that functions perfectly with the stock tune and includes the Mishimoto Lifetime Warranty, ensuring superior product quality and craftsmanship" but I remember that saw somewhere on the forum that different size of the pipe could cause troubles overtime with stock tune. doing around 650 miles a week so its a big question :)
Sgtstaadanko
Earth
2016 Civic EX-T
Not 100%, but I ran the Injen SRI for a while before getting Flashpro, I didn't notice anything, but then again I was unable to monitor a/f ratios to look for rich or lean conditions. The Mishimoto warranty would only cover the new intake, it's not like they're giving you a whole new powertrain warranty. The only "advantage" would be being able to hear the turbo more, without a tune you're not going to see drastic, if any, power gains.
Mishimoto
New Castle, DE
2017 CTR #1254
Thanks for the purchase!
It's only Si models that affect how this intake will perform. The Si has a different sized MAF housing, so you should not run the intake on that engine. We are working on designing an intake that specifically fits that car. The intake we currently have available is a direct fit for the EX-T, it will run great with no issues! Let me know if you have any other questions.
-Diamaan
Akalawur77
PA
2017 Civic Si Coupe
-Diamaan
So is your intake piping the same diameter as the stock piping to provide the same MAF scaling? And if so then how come hondata provides different maps for different intakes and what would be the different parameters between these maps if the MAF scaling is the same?
It's not the same. Some consider it "close enough". Not something I'd personally run on a stock tune.
Akalawur77
PA
2017 Civic Si Coupe
I agree that "close enough" definitely would still run different. I wonder how sensitive the car is to it though and how well it would "learn" and change short and long term fuel trims. I know Subaru's are very sensitive to Intake changes
Mishimoto
New Castle, DE
2017 CTR #1254
Our intake piping is different from stock. The MAF sizing is slightly different. I outline this in detail in our second update to that project. Check out the link below.
The Civic Has Boost! - Intake R&D, Part 3: Dyno Results
