I don't know exactly why but it's common. I think it's designed to achive 100% tps before the pedal hits the floor.Just kinda curious here, but how’s the TPS over 100%?
What is your dyno power?My dyno log (TSP stage1 non-si, cold high humidity):
86salmon's log:
So the TD03 flows ~190g/s at an approximate temperature of 80F vs ~160g/s of the normal stock turbo and ~170g/s of the Si. Although that is nowhere near the supposed 30% higher flow, it should stand up to the 260whp promise quite easily.Here's a log with a 3rd gear pull. Timing was nudged up from there on what is likely the last revision
241hp/226whp - 396nmWhat is your dyno power?
You have any vids?Getting close to the limits of the TD03 in street tuning. Maxing at 26psi boost and a good amount of timing. Hope to hit a dyno next week or week after
At 3500rpm it PULLS
I might need new tires soon![]()
No cameraYou have any vids?
Damn lol all goodNo camera![]()
Stock turbo on flex fuel can make 270-280whp if I remember correctly. You can probably get a flex fuel kit and push it even moreSo the TD03 flows ~190g/s at an approximate temperature of 80F vs ~160g/s of the normal stock turbo and ~170g/s of the Si. Although that is nowhere near the supposed 30% higher flow, it should stand up to the 260whp promise quite easily.
Thanks for sharing @86salmon ! Wish you enjoy your ride![]()
looks like it hits 26 psi and goes back down to 23 after 6k rpmHere's a 3rd gear pull after final revision. Tried to get a 1st-4th, but damp road has tires breaking loose all of 2nd and 3rd when WOT. Super fun to do, but not the best for data or my tiresHopefully with another day of dry weather and I'll get one to post. Looking to get on a dyno next week.
Ya, 26psi at 3500 rpm. The butt dyno feels it then too lollooks like it hits 26 psi and goes back down to 23 after 6k rpm
Yeah I get that too with W2 but hold 26 psi from 4k to redline without dropping boostYa, 26psi at 3500 rpm. The butt dyno feels it then too lol
Makes sense. W1 is biggerYeah I get that too with W2 but hold 26 psi from 4k to redline without dropping boost
