No problem. It's recommended to get a new washer for the drain plug.Thank you!!! Swapping in some AMSoil synchromesh this weekend.
Agree 100% - when I changed my transmission fluid on level ground, approximately 0.1 quarts remained in the transmission pan. This amount was deposited after I lifted the car and had it rest on two front jack stands.it takes however much fluid it takes to fill it to the check plug,
you can't just dump 2 liters in it, and walk away
the capacities listed in the manual are estimates only
