I'll pay attention the next time I'm on the road on Monday.Hello, I'm curious on what RPM range does the manual 1.5T stays at around 75-80MPH?
I'm also curious if the hatch and sedan varies with RPM?
Thanks.
Must be the extra drag of the hatchback. I have no problem staying above (usually well above) 40 mpg at 70 mph.gas mileage drops to 35ish per gallon when cruising over 70, I commute 85 miles a day and 70 of it highway.
Maybe a little. Probably some inaccuracy in the tachometers.Interesting that the hatch Sport is running 18" wheels but is turning 100 rpm higher at 70 mph than the 17" wheeled sedan. Must be the OD of the tires is actually smaller on the Sport?
In Winter my hatch gets like 35-37 on the highway, more like 38-39 when it was warmer.gas mileage drops to 35ish per gallon when cruising over 70, I commute 85 miles a day and 70 of it highway.
good to know! I set cruse at 70 usually, I'm happy with anything over 30 either way my odyssey only gets 20 on a good day with no wind going down hill. hahaIn Winter my hatch gets like 35-37 on the highway, more like 38-39 when it was warmer.
These are 100% correct as i jave and others have quoted them before1.5 Turbo EX-T Manual:
65 mph: 2500 rpm
70 mph: 2650 rpm
72 mph: 2700 rpm
Most I could get. Will update if I get more.
Agreed it has extra drag.. But the temp is problably the larger contributor to the differenceMust be the extra drag of the hatchback. I have no problem staying above (usually well above) 40 mpg at 70 mph.
No wind, 67 deg F, 49 mpg at 70 mph.
I did 75 to 80 mph on premium.. Hense my post titled premium fuel.. Almost half higjway half backroad.. Many hills.. And netted over 40mpg.. Actually about 45mpg if memory servesAgreed it has extra drag.. But the temp is problably the larger contributor to the difference
Rule of thumb is 2.5% mpg drop for each 10 deg F. So that would put my sedan at: no wind, 27 deg F, 70 mph = 44.1 mpg. ... which sounds about right to me.Agreed it has extra drag.. But the temp is problably the larger contributor to the difference
