joenobodyyet
- Aug 22, 2017
- 2
- Philadelphia, PA
- 2008 Honda Civic LX (automatic transmission)
Hello, I recently purchased an automatic transmission 2008 Honda Civic LX with 56,000 miles and I am compiling a list of all preventative maintenance items that I should address to keep my car running like a top. My 97 Civic LX just died, so I would like to maintain it as well as I can.
I like to do things myself to save money, but I am not super knowledgeable about cars. I don't have a garage or all of the proper tools, but I learned a lot while working on my 97 LX. I am prepared to keep up with this car religiously.
Here are some of the things I've thought of, but if you could answer my questions, and also add to the list of things I should keep up with, I would greatly appreciate it!
-How often should I change the oil? I've been wondering about changing it more often than recommended. I assume I should continue using synthetic oil. Are there better brands for synthetic oil? How about brand and type of oil filter?
-My power windows in my 97 had some troubles. Should I silicone spray my windows' side trims to help them slide better, and help the motor switches last longer?
-What are thoughts on fuel additives? Oil treatment additives? Engine treatments? Injector cleaner? Which are the best brands/types? Should I even use them? How often? I've seen products such as SeaFoam, Gumout, Lucas, Chemtool, STP, and other brands.
-Should I change the power steering fluid? What brand replacement fluid should I use? How often? Is this something I can do myself? I would be checking YouTube, and I also have a buddy with a garage who can help.
-Should I change the brake fluid? How often? Just DOT 3? I assume there's a video on youtube with instructions.
-Should I change the automatic transmission fluid? How often? I've read that I shouldn't "flush". Could someone explain the difference between "flush" and "drain and refill", and why I should or should not? The Owner's Manual says I should use Honda ATF-Z1 fluid
-Should I change the coolant/antifreeze? How often? Manual says to use Type 2.
-The seller told me I need a new battery. I was pricing them and found CA: 512, CCA: 410, RC: 70m for $70 w/ 2 year warranty OR CA: 625, CCA: 500, RC: 85m for $80 w/ 3 yr warranty (I use coupon codes at Advance Auto Parts online). Is the $80 overkill? Thoughts on car battery selection?
-How often should I change the air filter? Are there preferred types/brands? I've heard of one that you reuse and add oil, but I figure I don't mind spending $10-15 periodically for a new normal dry filter. I used to buy FRAM filters from Wal-Mart.
-How often should I change the cabin air filter?
-I read that changing the fuel filter is unnecessary, especially because I think it's located in the fuel tank of my 2008 Civic LX.
-Should I clean the mass air flow sensor? I got CRC brand spray.
-Should I clean the throttle body? I purchased CRC brand spray.
-How often should I rotate the tires?
-I used to purchase cheap tires, but should I be looking for anything particular when buying new tires for this 2008?
-I check the tire pressure pretty often, especially with free air and digital gauge at some gas stations
-I'll change tires when the tread is low
-How often should I get a wheel alignment?
-Should I spray the undercarriage during the winter with water to remove salt? Just wondering if spraying water on the exhaust in the winter would cause freezing and damage.
-Is there a way to keep the muffler from rusting? I had an issue with my 1997 LX muffler rusting. The weep hole kept rusting closed, causing the muffler to fill up with water.
-Do I need to change the PCV valve?
-Change spark plugs and wires? How often?
-Check and change hoses. How often?
-Change brake pads and rotors. How often? I'm pretty sure I have drum brakes in the rear. Are those difficult to change?
-Check belts. How often?
-This is my first automatic transmission vehicle. Should I use the parking brake when parking? I've heard its better to use the brake than the just having the transmission in park.
-Opinions on when to fill gas tank? Should I not let it get less than 1/4?
-I read that there is NO idle air control valve in a 2008, so that won't need cleaning.
-I believe this has a timing chain, not a belt. Is there any upkeep on a timing chain?
If anyone can think of anything I forgot, or provide more insight on maintaining my vehicle, I appreciate it. Thanks!
