Marky
- Mark
- Dec 17, 2018
- 5
- 32
- 56
- Chicago
- 2018 Civic Si
- Vehicle Showcase
Thanks a bunch for this tip! I installed the Magic Collars in my driveway over the weekend with a pair of floor jacks and jackstands. Was time consuming but I wanted to be safe and followed your tip to remove the brackets on both sides when doing the rear install. I will say that mod alone has tightened up the feel of the car most notably felt when going over bumps or railroad tracks.Finally got around to installing them recently and wow. I have a lift and air tools so the most difficult part was the plastic clips holding splash guard in. Every single one must have been filled with the ground up rock the rotors like to grind down.
Yeah, it’s a little off.
A tip for the rear. Remove the 12mm bolt and detach the wire clip and hold back to give you some space so you don’t wreck the wires.
I was surprised the car still drives straight. If anyone had an alignment afterwards, I’d be interested in the before and after.
As other’s have said, it really improves the handling.
