OverRev
- PC
- Mar 5, 2019
- 2
- 30
- 30
- Vancouver BC
- 1993 EG5, 1999 EK9, 2019 FK8
Some would think the subframe won’t move but it’s not. Just Like the alignment bolts, if you hit a pot hole or bumps hard enough they would move. I track my cars and do alignment adjustment quiet often since we have the machine. By installing these spacers they centre all the bolts btw chassis and subframe, next time when you do alignment you could eliminate the subframe misalignment. For Honda, our car is just bolted together by robots without proper subframe alignment. At our Honda dealership, over 30% of “new cars” fail alignment when we do PDI, but of cus most customer don’t/can’t even feel the difference and believe the new car is simply “perfect” but it’s definitely not.
For galvanic corrosion some worry about. If you have bare steel and aluminum joined together yes that could occur. But both the chassis and subframe are coated, if you worry you can paint the collars too. The grease is there so you can position the collars easier, not for corrosion protection I believe.
Frankly if Magic Collars are specialized in manufacturing these spacers, I am sure they would have better or equal quality as Spoon since spoon do not manufacture any of these collars in house anyways. and most machine shop could have aluminum milled to under 0.05mm precision easily.
