Lowering with Eibach Pro on 19's. Will they rub?
J
BC
2018 Honda Civic Hatchback Sport Touring
Hey guys,
I'm thinking about lowering my HB Sport Touring with Eibach Pro Kit.
Problem is that I am currently running 19" rims on 245/35/R19 sport tires.
I don't know if my current wheel setup will work without rubbing?
Any help is appreciated.
Wheel Specs:
Offset: +45
Weight: 20.5 lbs
P.C.D: 5x114.3
Tires:
245/35/R19
Thanks in advance
GoldClass
Singapore
Civic Hatchback
I want to say that you will be safe.
The new tire width is 10mm wider than the stock 235/40/R18 tire (i.e. 5mm poke/offset).
The new wheel is now 5mm poke/offset.
Total overall offset is 10mm (less than 20mm wheel spacer).
Should be very safe.
Although the dia. is now 10mm bigger, there are ample well space for Pro. kit drop.
vancitysfinest
J
BC
  • #3
Thanks for the reply. I guess i'll go ahead and purchase a pro-kit!
