mbrishke
- Sep 25, 2021
- 5
- 15
- 0
- Colorado Springs, CO
- 2019 type r
Just bought a 2019 CTR with 16k miles. it was well maintained, completely stock, and as far as i can tell, hasnt been "returned to stock" every nut and bolt was in place, with none showing wear from being previously removed etc.
However, the boost seems a bit more laggy than it should for a turbo this size(I've owned and built 2 turbo RSX's).
it seems ever so slightly hesitant to build boost, starts building around 3k, by 4-4500 it tops out at 15PSI and starts dropping until about 9 at redline. I actually took it to honda, explained the problem, and they replaced the fuel pump recall, and told me the boost was fine, I argued with them for about 30 minutes, knowing the car should be making more boost than that, then the "master tech" told me it's because of elevation(colorado springs, 6,500ft) im like no way man, it would be waining down to only 9lbs from the factory rated 23. It doesnt feel terribly slow, so I'm wondering if maybe the gauge is just off somehow? But that seems unlikely.
Anyway, they said they have another guy who is good with the type R's that will be in tomorrow, but as much as I didn't want to do this myself, I'm going to go leak hunting tonight because I don't have much hope for them.
In the meantime, I was hoping someone on this forum might have some insight. Is there a most common area for the leak to occur? I checked the charge piping that you can get to without removing the bumper already(from intercooler exit to TB). And everything seemed fine. Thanks in advance for any response.
