Loud CVT whine when using paddle shifters in S mode ('19 Sport Hatchback)
raulnor516
O'Fallon, IL
2019 Civic Hatchback Sport
I'm not sure if this is an issue or normal operation, but I figure it can't hurt to ask. When I'm driving my hatch in "manual" mode using the paddle shifters, the transmission seems to be excessively loud. I can especially hear it above 3000 rpm, but it gets increasingly loud as revs increase, regardless of "gear" selection. It doesn't seem to be depending on temperatures, I only put it in S after the engine is warmed up and it makes the noise regardless of outside temps.
I've got less than 10k miles on the car, and there's no mods or flashing done to it. I do drive pretty aggressively but I've never launched the car or done anything stupid like holding down the brake. The car was test driven before I got it, I think it had around 50 miles on it when I bought it? Does this seem like a normal behavior or should I be concerned about damage to the transmission?
zspeed
Camden County, NJ
Do you have a sound clip or video so that we know how it really sounds like?
Civii
Los Angeles / Antelope Valley
2017 Honda Civic
Mine gets loud too but AFAIK that’s normal for a CVT. They’re pretty loud. Someone else with more experience might be able to chime in and correct me. :)
Feddy_Ace
Rancho Cucamonga, CA
2019 Civic Hatchback Sport CVT
I’ve experienced this too and only after aggressively driving a long time. I believe it’s from the CVT fluid getting too hot and not working as well to lube the internals. It doesn’t sound good and results in some sluggish acceleration.
If this happens once in awhile, then it’s not a biggie, but if you experience it more often then it might mean your fluid got cooked too much and you should change it.
That’s what happened to me. I changed my fluid and the bad noises stopped even when I drive like an asshole.
xjoshuax89
Josh
Maryland
Yeah curious about the sound. Got any clips? You also sure its the CVT not the engine?
raulnor516
raulnor516
O'Fallon, IL
It's high pitched enough that my phone camera doesn't seem to capture it well. It only happens in manual mode, the same revs in D or normal S don't cause the sound. I wonder if it might be the transmission complaining because it can't shift the cones around?
BarracksSi
DC
FK7DEMON
Trevor
Fairfax, VA
2019 Civic Hatchback Sport Touring
I noticed it when reversing up a driveway.
fkseven
NA
FK7
The cvt is noisy. It’s normal it happens all the time when I put it into S and use paddle shifters. Doesn’t happen at WOT with and without paddles.
BarracksSi
DC
@raulnor516
Does the whine sounds like this? (Timecode 2:37)
That's pretty much what mine sounds like, although maybe quieter. I hardly drive with it in manual "S", though, so I'll need to pay attention the next chance I get.
