Looks like CarAndDriver found out about the Type R overheating issues first hand
Zeffy94
Matt
Doylestown, PA
2018 Honda Civic Type R
https://www.caranddriver.com/reviews/a28115797/2019-honda-civic-type-r-reliability-maintenance/
They noted that Focus RS and GolfRs running alongside did not run into this issue. They also noted this was a common complaint on the CTR owner forums.
Low to mid 80s air temps at the track they ran in.
Honda revised the grille for 2020 but I don’t think it’s enough. Anyone with a 2020 want to chime in if they tracked their car in similar conditions?
Amazon
Athens
2009 Cobalt SS
I made a thread about this awhile ago. Absolutely no amount of grille redesign is going to fix the problem, a 380cu core for this engine is asinine. You can take the whole damn bumper off if you want, but the reality is that it really needs to be double that size. All of the competition have cores around double the size, the CTR is the anomaly.
For example, the Golf R's is 616cu and the RS's is 750cu. Even cars making significantly less power have significantly larger coolers than the CTR, the GTI has roughly 500cu and my car had a 525cu core. The last two cars are making 50-60hp less, yet have 31% larger coolers.
The very first and most important modification anyone should do on a CTR is the intercooler, even if stock considering how BAT sensitive the ecu is.
NapalmEnema
Alex
2017 M2, 2013 X5M, 2019 Type R!!!
I've read a ton on this and it feels like -
Intercooler + Oil cooler may be the ticket / possible grill increase flow but I don't think that does much personally
It does seem to be 'track specific' as noted in the article. On tracks with more carrying speed and straights it seems to do well, it's the short courses with a lot of speed turns and such that cranks the temps so hard on these cars it seems. Nurburbring has a lot of speed on it so no overheat for example during their testing. Also very cool in Germany I'd wager compared to some other track locations.
Zeffy94
Zeffy94
Matt
Doylestown, PA
  • #4
That is shocking that Honda is using such a small IC on the CTR. I never considered one before I realized how woefully bad it is, now I may pick one up in the future along with a tune.
Amazon
Athens
2009 Cobalt SS
How bad is the stereo? Is it something easily amended simply by swapping out the speakers and/or sub?
CbusHondaFan
New Albany, OH
2006 Si TW, 2019 Civic Type R CW
No bass at all, the subwoofer doesn't seem to do anything, tweeters give you ears fatigue after awhile, average clarity overall. It's a mess and my 2006 Si sounds much better! I swapped out the center speaker with a J/L audio speaker and it made a tiny difference. My main problem is the almost complete lack of bass, especially from the sub. It's definitely not a "Premium" system, at least not when compared to the Premium Audio in a 14 year old Si :thumbsdown:
Waynegro372
Kyle
Tacoma/Seattle
A mule
While I agree with all this and the stock IC is pathetically small there are handfuls of forum members who have upgraded to aftermarket ICs, oil coolers and larger radiators and still are overheating at the track. I still don’t think this problem has been totally solved yet.
spyder57
LA
ABP CTR
Moving to a larger after market intercooler will make things worse as it simply blocks more flow to the radiator.
There's a reason why the CTR TCR doesn't modify the intercooler. They use an improved radiator, additional vents from the front fog covers, vented hood, and larger grille.
Stay with whats proven on the track instead of hearsay.
dwag0588
David
Chattanooga, TN
2020 CW CTR, 2014 Mazda CX-5, 2006 NC Miata, 2018 Silverado 5.3 (work)
Bingo. The intercooler will have no effect on the coolant temps. Running a massively thicker intercooler will probably increase you coolant temps if anything.
NapalmEnema
Alex
That's why I think an oil cooler is part of the equation
DRKSYD
Steve
United States
2019 Honda Civic Type R
An IC retains cooling for the purpose of the tune, whether OEM or aftermarket. It only helps maintain power levels at any given level, with any tune, not cool an engine. Agree.
I don't think the "thickness" of the IC really matters in this case. e.g., PRL's is a bar and plate design and keeps over all engine temps. down in stop and go, for normal driving or spirited. The other point, would be airflow through the IC.
Assume you run 23 lbs of boost, is it 23 before, and after the IC? (OEM or not). Is that 23 lbs of boost, hitting maybe 30 on the inlet side because it can't flow fast enough? Which would cause the engine to work harder? (OEM or OEM on a tune)
It still comes down to engine temps. which means intake/exhaust side and cooling of fluids. It would be nice to see a FK8 with a good intake, IC, exhaust, inlet pipe etc., compared to the OE in question just for reference. 2020 model just adds more confusion as Honda thought they were addressing something but really doesn't help anything once any number of parts are changed anyway. No one buys this car to track it OEM, article doesn't address that.
What fuel, what oil, is in play in that sense. Assuming all 3 cars are stock.
Amazon
Athens
2009 Cobalt SS
Shit, I thought the system in my 07 and 08 Si's were a bit crappy compared to the Bose in my Speed3's. Think an inline amp upgrade could mend the bass issue?
GeezR
Cincinnati
Honda Type R, Caterham, VW Touareg, Chevy Volt
The August 2020 Road & Track also finally acknowledges the overheating issues of the Type R on a "hot track". Its review of the 2020 model says the slightly larger grill opening is "meant" to address that overheating issue. They describe that problem as of the few track issues they have had with the Type R.
Car and Driver also mentioned how a low fuel reading can trigger limp mode on the track. After four years of extolling the track virtues of the Type R, I guess late is better than never.
