Night Fury
- Jun 13, 2017
- 17
- 1,043
- 745
- Chicago
- Black Type R
- #16
Transmission is more likely to fail due to bad shifting or synchros than too much power.Besides not knowing how much the stock clutch can handle we really don't know how much the transmission can handle. So with that in mind wouldn't it be better to have a clutch that will breakdown/fail before causing harm to the transmission?
This is false and a loaded statement. There are a lot of variables at play and in the past I have done hard launches at 400whp on stock type-r LSD and stock level axles with slicks using an unsprung disc with no damage.Puck clutches can bust your diff or your transmission from clamping so hard abruptly.
How does the Stage 3 feels compared to stock?This is false and a loaded statement. There are a lot of variables at play and in the past I have done hard launches at 400whp on stock type-r LSD and stock level axles with slicks using an unsprung disc with no damage.
As for the torque capacity of the stock clutch. While SPEC was using my car for development, they measured the clamping force of the stock pressure plate, and calculated it with the disc size and material and say it should be rated for around 340ft lbs......again, lots of variables will cause clutch failure or a clutch to survive in a harsher environment than rated for.
I currently have the SPEC Stage 3 puck clutch for lighter weight as well as quicker more instant shifts on track.....road course, not drag strip.
That’s why I said “can” and not “will.” I respect your extensive real-world racing knowledge but I’ve also been following the aftermarket scene for almost 20 years. Back in my ITR days, puck clutches did break Honda transmissions and differentials here and there. Things may be better now with more modern designs but it did happen and buyers should still beware.This is false and a loaded statement. There are a lot of variables at play and in the past I have done hard launches at 400whp on stock type-r LSD and stock level axles with slicks using an unsprung disc with no damage.
I pushed the stock clutch in the mid 400wtq for a year without any slipping. Mind you this wasn’t for 100,000 miles but Clutchmasters say the 400 series maxes at 480wtq, and to stay stock until I was ready to spgrade to the twin disc 1725 kit with hydraulic bearing (also includes lightweight flywheel) and gives a much more stock feel just a bit different in learning the engagement timing. Very soft with the hydraulic and a must IMO.
...I pushed the stock clutch in the mid 400wtq for a year without any slipping. Mind you this wasn’t for 100,000 miles but Clutchmasters say the 400 series maxes at 480wtq, and to stay stock until I was ready to spgrade to the twin disc 1725 kit with hydraulic bearing (also includes lightweight flywheel) and gives a much more stock feel just a bit different in learning the engagement timing. Very soft with the hydraulic and a must IMO.
