LED side marker switch back question
Dcabrera211
Donny
Rockland NY
2017 Honda Civic si, 1989 Mustang GT convertible
I recently purchased a set of LED switch backs for my side markers to go on my '17 si. They are supposed to have a blue LED with the DRL and switch to Amber for the turn signal. I am stuck as they are not doing what they should.
- I have connected them to the socket for the stock side marker and also spliced into the turn signal (passenger side) and I am only getting a constant Amber light and no turn signal functionality. I'm lost on where I went wrong. I'll add pics to show what I've done and what they are expected to do. I have searched on the forum and have got nothing. Thanks in advance!
Honda Civic 10th gen LED side marker switch back question IMG_20200704_152842
Honda Civic 10th gen LED side marker switch back question IMG_20200704_152835
Honda Civic 10th gen LED side marker switch back question Screenshot_20200705-125318
Honda Civic 10th gen LED side marker switch back question IMG_20200704_153011
mmxx
PNW
2020 Si Coupe
Maybe you spliced the wrong wire. A youtube video showed me that you can connect the red wire into the socket (the top side of what you are holding) to test to make sure you got the right wires.
Dcabrera211
Dcabrera211
Donny
Rockland NY
Yeah, I believe I saw that one too. I tried it briefly but didn't get much. My other concern is that when I connect the side marker to the socket (where stock side marker bulb gets connected) it immediately turns Amber. I would assume it should turn blue, not Amber. I think that's where I'm confused the most. I'm obviously not too good with electrical lol.
DaiLo
19 Civic Hatchback Sport
You might have tapped into the daytime running light wire instead? I know when I did mine, the colors of the wires were not the same as the videos I was following. Probably a regional thing.
jayy_swish
Jay
The turn signal harness usually have 3 wires: a ground, a constant 12v, and the normal flashing when you activate the switch for the turn signal. Your probably tapped into the constant 12v. Black is ALWAYS ground so then just move the tap to the other wire that’s not black. If without the tap the blue light does not come on switch the connection 180°on the stock bulb connection
Dcabrera211
Dcabrera211
Donny
Rockland NY
That's where I'm confused. When I plug in JUST the side marker to the stock socket, it lights up Amber. The red wire isn't even connected. Weird right?
jayy_swish
Jay
And what happens with the red wire connected and turn signals activated
mmxx
PNW
2020 Si Coupe
I'm not familiar with this brand of side markers. Maybe it is by design that it holds amber and blinks blue for turn signal. The stock model is amber for just regular lights, maybe these folks are keeping that look.
Dcabrera211
Dcabrera211
Donny
Rockland NY
You know what that actually makes a lot of sense! I assumed that the turn signal would be Amber and the constant would be blue. Made sense to me that way I guess. I haven't had time to mess with it since then so I'll let you guys know if anything changes. I did just put a pre order in for unity performance side markers. They won't come till September (estimated).
Jens_sedanEX18
Jen
Jacksonville, FL
2018 Honda Civic Ex
Which color did you get? I’m debating on whether or not I should order a pair. I want the clear ones with amber led. My boyfriend thinks I’ll void my warranty if I add the side markers to my car. Seeing how I’m doing something with the electrical ??‍♀
DaiLo
It shouldn't affect the powertrain or drivetrain warranties. But if your power window goes out, they could claim the side marker did it but they'd have to prove it directly caused the failure, which is unlikely.
Jens_sedanEX18
Jen
Jacksonville, FL
2018 Honda Civic Ex
Not likely unless it's
Good deal. I ended up just getting them. Sucks I have to wait til September to get them. I think I waited to late. I know they come in batches so hopefully it won’t be long. Never did anything exterior wise modification so this will be a first for me ??
video looks like they’d be simple to install. Just plug and play.
Dcabrera211
Dcabrera211
Donny
Rockland NY
I ordered the clear with white LED. I saw that someone on Xgen FB forum said they opened up and I didn't hesitate. I bought my car used (2017 si) so I wouldn't know if it does or doesn't.
youo34
Jon
Toronto, ON, Canada
Honda Civic Coupe Sport 2019
Similar issue as you where, my DRL is amber and my white led lights only come on when I signal. Does anyone know if you can switch this order around where the amber only comes on when signaled? and DRL stays white led?
